It is currently Sat Feb 23, 2019 1:00 pm
PostPosted: Wed Aug 01, 2018 11:48 pm
Has thanked: 1 times
Hi there, we've recently started landscaping our garden. At the bottom of the garden we've removed some brick raised beds to make it easier to get access to the outbuilding. We're looking to re-landscape this area to…
  1. Create new raised beds out of sleepers
  2. Straighten the edge of the grass to make this area bigger
  3. Replace grass retaining wall with a wall made entirely of sleepers
There are some brick walls along the boundary that ideally we'd like to replace with something A. straighter, B. A single wall and B. that looks nicer. I'm thinking a wall made out of sleepers along the boundary would look nice. Can anyone suggest how I need to go about this? As you can see the walls are a bit wonky but they're right on the boundary and the neighbours garden level is higher than ours. Are they retaining walls? If we remove the walls to replace them are we going to run into problems?
File comment: More brickwork to be removed.
File comment: The walls on the boundary.
File comment: We want to cut off a chunk of the grass (in line with the line post). Would we need to extend the wall along the fence here?
File comment: The bottom of the garden.
PostPosted: Fri Aug 17, 2018 6:43 pm
Has thanked: 19 times
Been thanked: 2 times
Looks like there might be some solid concrete under those bricks? Either way, shouldn't be an issue as the garden levels don't appear to be hugely different - you could remove the brick and if it is concrete beneath just dress it with a sleeper (or if really keen break out the concrete too).
Timber sleepers can be used as retainers too.
cron
