It is currently Thu Jan 24, 2019 4:31 am
PostPosted: Fri Jan 11, 2019 7:11 pm
Been thanked: 4 times
Hi all
I'm sorting out the loft in a house I've moved into and the next job is to lag the naked pipes. There's a mixture of 15mm and 22mm.
1. What's the best foam product to use. Some day thick grey stuff is fine, others say to use Armaflex / Tuflex, and that even those won't stop a freeze in the extreme cold (at which times they say you should leave your loft hatch open to prevent freezing)? So firstly, what to buy?
2. If a pipe is clipped to a joist and will be covered by the loft insulation, should I still lag it?
3. Some pipes are clipped to the rafters or are clipped to vertical timbers. How can I insulate them?
4. We've got several outside taps, do I need to insulate the the small amounts of external pipework?
5. Pipes around the house, underfloor boards (some are accessible), not boxed in, etc. Is it a good idea to lag these where possible from an energy saving point of view? I've read that it is, but then I also think they give off heat. So that one's always confused me!
We are in rural Wales and I just want to make sure I get it right first time, so any advice most appreciated. I've also just been reading about trace heaters... Overkill or good idea?
Cheers
PostPosted: Sat Jan 12, 2019 9:54 am
Has thanked: 1509 times
Been thanked: 3840 times
normal grey insulation tube i fine
Can't do any harm
use the same grey insulation tubes, they have a split along the length for installation
Yes, however you would do better to isolate the water supply to outside taps and leave them open over winter.
Under ground floor then insulate as in extremely cold weather they can freeze due to cold air coming through the air bricks.
Cheers
