Ultimate Handyman Home
lafarge plaster boards
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum
fin
PostPosted: Thu Oct 23, 2008 5:16 pm    Post subject: lafarge plaster boards Add User to Ignore List Reply with quote
anyone have issues with the quality of these? i normally use the 4 x 3 base boards
well i say 4 x 3 for some reason there 3ft by 1200mm. plaster boards are normally 1200mm x 900mm or 4ft by 3 ft
there also always warped when they come from the builders merchants.
they dont cut well. the backing peels off too easily
when they are screwed to stud work the corners break as soon as the screw head starts to go flush with the board surface.
when plaster is applied to them the paper can bubble through the plaster (the boards are on the correct way) or the open edges crumble to mush)
anyone else have these issues?
Back to top
Pristineplastering
Member
PostPosted: Thu Oct 23, 2008 5:44 pm    Post subject: Add User to Ignore List Reply with quote
Hi Fin, look what I posted on the Plasterer's forum only last week...
I hadn't ever given it any thought but has anyone else noticed the difference between British Gypsum boards and Lafarge GTEC ??
Been dabbing an extension out the last couple of days and have lost count the amount of times the Lafarge boards have crumbled like chalk when trying to cut a clean edge - They're bloomin' useless , edges all mishapen when I have managed to cut a reasonably straight edge , me Surform's been working overtime
I thought they might be damp but a new delivery arrived today and exactly the same problem - Bring me BG boards anyday !!!
Back to top
Pristineplastering
Member
PostPosted: Thu Oct 23, 2008 5:46 pm    Post subject: Add User to Ignore List Reply with quote
Needless to say, I had many replies slating these boards just as you have - I only ever use BG boards as a rule but the contractor I was working for had a job lot of Lafarge delived - As you say , they're bloody useless
Back to top
fin
PostPosted: Thu Oct 23, 2008 6:13 pm    Post subject: Add User to Ignore List Reply with quote
when i was in the builders mercahnt the other day i was havin a cuppa wif the yard lads. they said they get loads of complaints about them. they come from the factory without a pallet there just on kickers (small bits of pallets basically) so when the forklift picks them up they get all bent out of shape.
never had an issue with british gypsum boards. much better than this shite
Back to top
fin
PostPosted: Thu Oct 23, 2008 6:21 pm    Post subject: Add User to Ignore List Reply with quote
pristine plastering, have you got a link to your thread? or the title? i couldnt see it anywhere
Back to top
Pristineplastering
Member
PostPosted: Thu Oct 23, 2008 9:27 pm    Post subject: Add User to Ignore List Reply with quote
Its on another forum - www.plasterersforum.co.uk - About the 3 page in , Lafarge GTec versus Bristish Gypsum
Back to top
Dr Frankenstein
Junior Member
PostPosted: Thu Oct 23, 2008 9:30 pm    Post subject: Add User to Ignore List Reply with quote
Yep, they're cr*p!!! British Gypsum better!!!
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plastering Forum All times are GMT
Page 1 of 1
