www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
-> Central Heating & Boilers |
| Author |
Message |
thescruff Senior Member
Posted: Mon Dec 01, 2008 10:09 am Post subject: |
Could be the iron /bracket.
TBH, I would take the stat and shift it so they can see each other, that way you can test for a sighting problem or stat/reciever problem. _________________ Scruff |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
Posted: Mon Dec 01, 2008 10:37 am Post subject: |
when its not working, is the green light on, on the receiver? _________________ www.hintonheating.com
| Back to top |
Lemon Junior Member
Posted: Mon Dec 01, 2008 11:02 am Post subject: Digistat SCR |
I have done that. Thanks. The British Gas man has just been. He said the most bizarre thing ever to have affected a wireless system was a goldfish bowl. The answer was to move the goldfish bowl by about 18 inches, and that solved the problem! Let's see how I get on this week.
When it does not start, green light is not on, but the red one is sometimes on, steady. Not always. |
| Back to top |
Lemon Junior Member
Posted: Tue Dec 02, 2008 2:25 pm Post subject: digistat scr |
Some good news, I think. Thanks to the forum and the gas Man and maybe my wife.
My wife glared at the system and was very CROSS on the cold mornings.
I moved the metal thing which holds the iron when it is not in use. Moved it well away from the receiver (It was next to it).
Also, I moved the transmitter further away, and about the same height, approx 15 feet away. Through 2 doors now.
Fingers crossed, it has worked on three occasions now, so maybe that combination has solved the problem. Probably the metal thing next to the receiver. (Not sure what you call it, younput a hot iron into it uprght for storage)
Thanks for help.
PS the Gas Man said that another bizarre solution was to move a mirror. The mirror had caused the wireless doo-dah to work sporadically in one house.
Lemon |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
