It is currently Thu May 24, 2012 1:27 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Mon Jul 25, 2011 7:33 pm
Ok ive just plasterboarded (dot and dabbed) where my shower is going. I put a batton behind the board (in between the two pipes) where the mixer will screw to and the holder for the head. In my haste I didnt even think to put a batton in for where the enclosure screws to :cb
Typically the dots and dabs are either side of where the screw fixings (theres 3) need to go for the enclosure so theres basically 12.5mm MR plasterboard and then a 3/4in void behind. Ie not ideal for screwing the enclosure to!
Are the any fixings that can be reccommended for such a job that spread their load behind the board? Or do I need to start cutting my lovely neat wall out :cb
PostPosted: Tue Jul 26, 2011 7:21 am
Could you not put a few holes in and squirt board adhesive foam in there??
PostPosted: Tue Jul 26, 2011 8:36 am
Has thanked: 58 times
Been thanked: 272 times
Can't you just use longer screws. I would go for exterior wood screws which you can get up to 4 inches long.
PostPosted: Wed Jul 27, 2011 9:06 am
Has thanked: 3 times
Been thanked: 30 times
To be honest this shouldn't be a problem, as op's has stated just use some longer screws. The ones usually supplied are about 50mm so they should reach the masonry behind also use a good quality adhesive silicone as well and that will be more than adequate.
Plus what is the finish going to be tiles or multi-panel?
PostPosted: Wed Jul 27, 2011 6:08 pm
Its gonna be tiled mate
PostPosted: Thu Jul 28, 2011 3:33 pm
If the tiling is going past the cubicle then this will also be adequate to fix to
PostPosted: Thu Jul 28, 2011 3:40 pm
If it is siliconed and the plugs go through the tiles, then it will be absolutely fine
Users browsing this forum: No registered users and 7 guests
