It is currently Fri Jan 18, 2019 1:26 am
 Post subject: Issues with Screw
PostPosted: Sun Dec 31, 2017 12:29 pm
Been thanked: 1 times
Happy new year people,
I have been doing some DIY but I am unable to remove a screw from a hinge in an oak frame. I have tried a screw removal kit, but that resulted in the following picture (Top right screw). I need to remove the screw to fit a new hinge. Any advice would be grateful.
 Post subject: Re: Issues with Screw
PostPosted: Sun Dec 31, 2017 12:39 pm
Has thanked: 1187 times
Been thanked: 1080 times
Drill the head off. Remove remaining "stump" with pliers etc, one hinge is removed.
Make sure you have the correct, unworn bit when removing. I prefer to use a hand screwdriver of the bit holder type rather than a drill driver to remove old screws.
PostPosted: Sun Dec 31, 2017 1:15 pm
Has thanked: 697 times
Been thanked: 2014 times
you need a pz2 bit star within a star for those screws NOTph2
PostPosted: Sun Dec 31, 2017 1:21 pm
Has thanked: 101 times
Been thanked: 247 times
On more than one occasion I've used a nail punch to knock the screw counter clockwise then once it's turned a little I've been able to grip it with side cutters.
PostPosted: Sun Dec 31, 2017 1:29 pm
I quite fancy a pair of these
https://www.amazon.co.uk/Pliers-Unique- ... B000TGNVUG
Expensive for occasional use though, and you still have to get the screw out enough to grip it.
PostPosted: Sun Dec 31, 2017 2:30 pm
Been thanked: 5 times
Right I've tried this and it worked, sounds a bit odd but..
Put an elastic band over the top of the screw, then your screwdriver and it will grip and turn
Worth a try and no damage!
PostPosted: Sun Dec 31, 2017 3:54 pm
Has thanked: 31 times
Been thanked: 100 times
I have a pair of those they are the dogs whatsits for worn screws!
For this message the author toolbox has received gratitude : Dave54
PostPosted: Sun Dec 31, 2017 3:55 pm
You might well have tempted me! :mrgreen:
PostPosted: Sun Dec 31, 2017 4:39 pm
I had a pair years ago used to be the only tool that would shift rusted round head burner screws out of cooker hotplates, till some scrote broke into my van!
Saw these and got some only had to use them once so far but they worked a treat!
PostPosted: Sun Dec 31, 2017 4:50 pm
They'd be handy for anybody working on appliances I reckon. Used to be a regular with electric cookers when I was doing electrical work. "Can you have a look at the cooker while you're here" The screws can be "difficult" sometimes :mrgreen:
 Post subject: Snapped Screw Removal
PostPosted: Sun Jan 07, 2018 8:01 pm
Hi people,
Due to an earlier post I have managed to remove the hinge, but I had a stubborn screw which head is now snapped. How do I go about removing the screw body in the wood? Picture is attached.
Best regards
Ray
PostPosted: Sun Jan 07, 2018 8:17 pm
UHM Super Moderator
Has thanked: 56 times
Been thanked: 92 times
I've merged the new thread with the previous one.
No need to start a new thread in this case.
PostPosted: Sun Jan 07, 2018 8:24 pm
sometime if theres enough sticking out you can take a drill with a chuck on low gear close the chuck tight on the screw stump and turn by hand
PostPosted: Mon Jan 08, 2018 12:07 am
Old School Chippie
Has thanked: 768 times
Been thanked: 1538 times
If the drill trick doesn't work (and it doesn't always) cut the timber around the shank of the screw back a few millimetres using a sharp chisel or even a Stanley knife (it will all be covered by the hinge leaf in due course). You are aiming to get a sort of "moat" around the steel of the screw big enough to get some needle nose pliers in there with which to unscrew the offending broken screw.
If you've been lucky it may be possible to replace the screw like for like, or maybe with one which is the same size but a bit longer, but if the hole is too big for that (you may have had to dig a lot out) then the hole can be tidied-up and enlarged by drilling out with a larger twist drill (say 8 or 10mm) and an appropriately-sized hardwood dowel is then glued and knocked-in. Once the glue has set any dowel still sticking out can be trimmed back with a fine saw and sharp chisel to be flush. When you refix the hinge the plugged hole will need to be pilot-drilled before you screw it because otherwise the timber might split (as it's hardwood)
