It is currently Sat Mar 17, 2018 4:41 am
Visit Thermo worx
 Post subject: Isolation Valve Adapter
PostPosted: Mon Jun 19, 2017 7:39 am
Has thanked: 3 times
Been thanked: 6 times
Morning All,
I've been wanting an outside tap in my garage since we moved into the house a 3 years ago but never got round to it. Well i'm getting round to it now.
As the boiler is in the garage, i've got easy access to the relevant pipes however i don't want to cut into a pipe. At the moment there is a section that's been t'd off with an isolation valve ... AtCh8P8HAQ
which feeds the water dispenser to the frige freezer. My initial thought would be to buy one of these ... ap+adaptor
however, as you may have noticed straight away (which i didn't), it doesn't fit into the Isolation valve. Is there an adapter i can get that will make this worth or am i just making things harder for myself with not wanting to cut into the pipes?
PostPosted: Mon Jun 19, 2017 8:02 am
Has thanked: 39 times
Been thanked: 1200 times
The more "bits" you have the more chance there is to leak.
I would cut the pipe, fit a yorkshire T piece (you solder them) then an isolation valve, then pipework to your tap. (all soldered)
PostPosted: Mon Jun 19, 2017 1:21 pm
Been thanked: 34 times
That adaptor (from Amazon) you have listed is designed to screw onto an outside tap and provide two further outlets. Its no use for what you want to do. An easier approach would be as follows:
1. Get a small length of 15mm copper tube, two 15mm compression tee's, a non-return (check) valve and a 15mm compression drain off.
2. Turn of isolation valve, cut pipe on fridge side of valve, insert compression tee (with unused opening facing down).
3. Cut a short length of tube, insert into unused part of tee, and attach non return valve (arrow facing direction of flow).
4. Further short piece of tube to other side of check valve.
5. Attach second tee to tube, and via another short piece of tube, attach drain off. Leave unused opening right or left, or pointing through wall if tap going outside,
6. Connect tap to unused opening via further length of tubing.
If you can solder, all compression items except check valve and tap could be replaced with soldered equivalents.
You could also use push fit fittings and plastic or copper pipe (remembering the inserts if using plastic pipe).
The isolation valve will limit the flow, but to replace it with a full bore one you'd have to turn the water off at the mains.
