It is currently Thu May 24, 2012 1:15 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
PostPosted: Thu Dec 08, 2011 5:50 pm
Has thanked: 4 times
Been thanked: 1 times
Hello
I`m unable to isolate the inlet water supply`s to the shower.
I can reach 1 of the valves (the red one on the black tank that`s above the cylinder) but the other one is in such a position that it`s impossible to reach/grip to turn it off, It`s behind the blue cylinder.
Can I get round this buy turning the water off at the mains, then run the hot and cold taps to empty the system to change the thermostatic cartridge on the shower ?
We live in a flat so all`s on one level
The boiler is Worcester Greenstar 24 ri
http://www.worcester-bosch.co.uk/homeow ... nstar-24ri
which is situated in the kitchen.
Thanks for any advice
Kim
PostPosted: Thu Dec 08, 2011 5:55 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
ys you could turn the mains off and run the storage tank out.
To save the hot water just open the tank cold taps
For this message the author thescruff has received gratitude : kimbo3213
PostPosted: Thu Dec 08, 2011 6:17 pm
thanks scruff
Is the storage tank the one above the cylinder?
not sure what you mean here
PostPosted: Thu Dec 08, 2011 6:39 pm
OAP
Yes thats the one.
The cold connection is lower in the tank than the hot so if you open just the cold taps you will keep the hot water in the cylinder.
Ok you may have to drain a little bit when the cold stops.
PostPosted: Thu Dec 08, 2011 7:02 pm
so if I turn the mains off then run the cold tap until it stops, then run the hot tap for a little bit (or until it stops) i should be able to remove the thermostatic cartridge?
thank again
Kim
PostPosted: Thu Dec 08, 2011 7:22 pm
OAP
Looks like a good plan :thumbright:
Make sure you isolate the sparky bits first.
PostPosted: Thu Dec 08, 2011 9:04 pm
thanks scruff, i`ve got the part coming in a couple of days, i`ll let ya know how i got on.*fingers crossed*
PostPosted: Thu Dec 08, 2011 9:24 pm
OAP
You'll be fine if you take your time.
I'm outer here in a while till next week but someone should be around if you need help.
PostPosted: Tue Dec 13, 2011 1:04 pm
Hi scruff, just to let you know that the part arrived today and was fitted without any problems.
thanks again for your guidance
For this message the author kimbo3213 has received gratitude : thescruff
PostPosted: Tue Dec 13, 2011 1:23 pm
OAP
Well done, Thanks for the feedback :thumbright:
Users browsing this forum: carder1 and 27 guests
