It is currently Sun Mar 24, 2019 3:08 am
 Post subject: Is this a 'mini-lintel'?
PostPosted: Wed Aug 08, 2018 8:32 am
Has thanked: 1 times
I am in the process of knocking out a bricked up fireplace and have come to a course of blocks at about 600mm high which are more the sort of material you would expect of a lintel but are in separate blocks (three span the opening). I have just read another post that refers to a 'mini-lintel' and wondered (a) if this is what I have found, and (b) if that means it is safe to take these blocks out? Clearly, to insert a fireplace I need to open up to about 700mm so this is in the way! The house is a townhouse built c. 1880 and this is the fireplace in the main sitting room.
Any advice about this job gratefully received!
PostPosted: Wed Aug 08, 2018 9:15 am
Has thanked: 410 times
Been thanked: 1517 times
A lintel has to be one continuous piece, if it's three separate pieces it's not a lintel.
Fireplaces do often have an arch (or a lintel) higher in the chimney breast than the fireplace opening you initially see when you begin to expose the brickwork close to the fire.
For this message the author ayjay has received gratitude : AL1308
PostPosted: Wed Aug 08, 2018 11:56 pm
Thanks for such a quick answer - much appreciated. I’ll get back to work!
