It is currently Thu May 24, 2012 1:08 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jan 10, 2012 10:25 am
Has thanked: 110 times
Been thanked: 1 times
fin wrote:
yes. snap it and then replace. easy. and cheaper. try a google search for euro cylinder
You mean snapping with screw in it and pulling with hammer? If yes, i wonder how that latch which holds cylinder is pulled away...
I'm n00bie in DIY
PostPosted: Tue Jan 10, 2012 10:31 am
Been thanked: 66 times
the cylinder will snap where the screw goes through it that secures it to the door. you can buy other types which snap in a better manner to deter thieves.
For this message the author fin has received gratitude : Boris_yo
PostPosted: Tue Jan 10, 2012 10:39 am
So should i do like this?
Will i need to use screw that fits tightly?
P.S. I was offered Yale cylinder which was almost 2 times more expensive. I also say on YouTube Yale anti-lock cylinder. Did you mean this cylinder when told that i can buy other types which snap in a better manner to deter thieves?
Anti-lock and anti-bump are not related?
I'm n00bie in DIY
PostPosted: Tue Jan 10, 2012 11:26 am
i would have thought so boris. otherwise the screw will come out. i will say ive never had to do this. but no doubt will do one day.
my dads done it before with a cold chisel and a mash hammer.
PostPosted: Tue Jan 10, 2012 11:27 am
these are something like what i meant http://www.discountlocks.co.uk/Anti-Sna ... tAodgEC8Ag
PostPosted: Tue Jan 10, 2012 4:00 pm
I liked anti-snap and turn cylinder. Won't require finding keys to unlock my room's door and more convenient than this euro cylinder that i have bought recently:
I'm n00bie in DIY
PostPosted: Tue Jan 10, 2012 4:21 pm
Has thanked: 15 times
Been thanked: 161 times
In your 1st picture it shows the door unlocked, plus the screw which retains the lock has already been removed.
Why dont you just slide the lock out and fit the new one.
If its stiff give it a good belt with the hammer.
PostPosted: Tue Jan 10, 2012 5:15 pm
hasnt he lost the key though? as the keys normally needed to remove it hence the question about snapping the lock
PostPosted: Tue Jan 10, 2012 5:43 pm
I changed one last year, the key had snapped in the lock but was in the unlocked position, same as original photo, I just took the holding screw out and could remove the barrel.
PostPosted: Tue Jan 10, 2012 5:53 pm
Has thanked: 57 times
Been thanked: 99 times
The metal arm coming out the side of barrel will not be in line,so will not pull out,I did one at xmas and just drilled it out,used a pilot bit then larger,then you can line metal arm up and pull out,took about 10 mins,surprised how easy it was
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Tue Jan 10, 2012 11:15 pm
Must i choose correct bit carefully? If yes, which drill bit must it be and what is pilot drill bit? Isn't lock snapping with screw easier and less hassle compared to drilling?
I'm n00bie in DIY
Users browsing this forum: No registered users and 6 guests
