Hi, any advice would be greatly appreciated
I have started tiling as advised right in the centre of one wall, the tiles I have are 250mm x 400mm. I have come to the bit where I need to continue the tiles on the walls either side (hope that makes sense?) I have been left with 300mm (cut) tiles at each end, do I continue the tiling using the off cut (150mm) from the first wall tiles, or do I start the tiling on those walls in the centre again??
Sorry if the above is a little unclear!
Many thanks again
Rusty
