Page 1 of 1
[ 4 posts ] |
| Author |
Message |
lagi
Posted: Fri May 20, 2011 12:09 pm |
| Senior Member |
Joined: Mon Dec 22, 2008 6:09 pm Posts: 1589 Has thanked: 80 times Been thanked: 38 times
I have 2 and a bit walls to render internally. I have fixed some 12.5mm plasterboard offcuts as a ruling off guide. All backboxes have been countersunk the same.
There is no immediate hurry to plaster after as have other things to do first.
I will probably get someone in to get this on, so the big factor is time.
It will be on thermalite blocks which i have done before.
But at a rough 12.5mm to 15mm render should i go for just the one coat. (reason being it will be based on day rates.) Have done 2 coats previously.
Or go for hardwall as this can be done in a day?
| Top |
lagi
Posted: Mon May 23, 2011 3:03 pm |
| Senior Member |
Any thoughts as someone coming round to have a look, be better if i can tell them what i want.
| Top |
register or
log in
Crooksey
Posted: Wed May 25, 2011 12:11 pm |
| Senior Member |
Joined: Sun Jan 03, 2010 3:16 pm Posts: 303 Has thanked: 0 times Been thanked: 26 times
I wouldnt one coat, I would just do it in two coats of render.
If you haven't got the cash, have it hardwall'd. But you can't beat rendered walls.
_________________ My project blog - Check it out
| Top |
register or
log in
lagi
Posted: Fri May 27, 2011 4:16 pm |
| Senior Member |
Thanks, i have the sand, no cash. The guy wants to hardwall it then skim it over two days.
It will be price dependant.
| Top |
register or
log in
Page 1 of 1
[ 4 posts ] |
