Ultimate Handyman Home
Interior Wall fix
Goto page Previous  1, 2, 3
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
PeteW
Junior Member
PostPosted: Thu Oct 02, 2008 9:07 pm    Post subject: Add User to Ignore List Reply with quote
Update...
Just to check I'm on the right path...
PVA'd wall and have started to lash up first render coat to fill gaps and front of slates..
 Description:
 Filesize:  144.12 KB
 Viewed:  232 Time(s)
Back to top
Tryanything
PostPosted: Thu Oct 02, 2008 10:15 pm    Post subject: Add User to Ignore List Reply with quote
Why dont you just fix plasterboard straight onto the uprights scratch
Be a lot quicker and easier, and wont come out any further than plaster
Tony Tiger
Back to top
izalarfin
PostPosted: Fri Oct 03, 2008 4:12 am    Post subject: Add User to Ignore List Reply with quote
your scratch should look like a line of wwwwwwwwwww about 2 inch apart but as shallow wave's.
knock some 2 inch nails though a old bit of batten. don't smooth the render face, scrape your trowel lightly up it using the edge
so it leave the render face open and course like a rough piece of sandpaper ? no shine. don't use pva just damp with water
that's the best glue for cement keep it damp as you go, it will make the slate slippery but you'll never get the cement off it when its dry and hard.
( I'll look back when I get home tonight).
Back to top
PeteW
Junior Member
PostPosted: Fri Oct 03, 2008 6:33 am    Post subject: Add User to Ignore List Reply with quote
Mainly because the slates are moving and slipping with every slight tape of the wall. Loads of old render came out, even though it looks like alot of render on the wall.. its really only just the gaps filled and smeared over the front of the slates theres no real depth to it at all.
Back to top
PeteW
Junior Member
PostPosted: Fri Oct 03, 2008 6:36 am    Post subject: Add User to Ignore List Reply with quote
Plasterboard will be the way I go probably as well... but wanted to secure the slates and build up a layer that I then dot and dab too.. the edge of the door frame is the line where the plasterboard will sit.....
I kinda thought I was following suggestions.. fill gaps, scratch coat, plaster board or plaster or eml etc etc Crying Thumbright Thumbright Thumbright
Back to top
PeteW
Junior Member
PostPosted: Fri Oct 03, 2008 6:39 am    Post subject: Add User to Ignore List Reply with quote
I'm lost a bit here.. sorry Smile the "w"'s and the batten :)
Back to top
PeteW
Junior Member
PostPosted: Fri Oct 03, 2008 7:37 am    Post subject: Add User to Ignore List Reply with quote
I get it now izalarfin ... I'm being a bit slow.. scratch a wavey line into the surface..
Cheers.. i just had to read it a few times doh! Razz
Back to top
izalarfin
PostPosted: Fri Oct 03, 2008 5:47 pm    Post subject: Add User to Ignore List Reply with quote
I could of explained it better but I was a bit pushed for time this morning my mate was due to pick me up in ten minutes.
what you do is make like a rake head with the nails and batten, keep the nails in a straight line, and leave a blank bit of batten for a handle,
this makes it very quick to scratch a wall. I use one about 2 foot long including handle but this size would be in practical between them laths
but a small one to suit will save you time.
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 3 of 3
