It is currently Wed Feb 20, 2019 7:40 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Apr 21, 2018 6:01 pm
My bedroom was built in 2003, before the changing of colours of wires. At one end of the room there is a light switch, but there is a pullcord by my bed for the days I am unable to get out of bed and turn on the light by the door.
I've been wanting to replace the light switch at the door with a dimmer switch for a while. I managed to replace it yesterday and it seemed to work. I wasn't able to switch the light off from my bed. I checked the dimmer switch to see if there was a common terminal, and there wasn't.
The terminals I do have are an earth, L2, L1 and a wavy line with an arrow going through it, which I'm thinking is the load?
I've got a variety of wires. 2 red, yellow, black, blue, and a thick grey wire with a red line. I'm going to go back to Homebase, because the dimmer doesn't allow the L1 screw to tighten or loosen, and I may get a testing pen too.
How should it be wired up? Does one of the red wires go in L1 and the other L2? Which goes in the wavy line? All these questions!
PostPosted: Sat Apr 21, 2018 6:08 pm
Has thanked: 40 times
Been thanked: 1429 times
Life is never easy is it.
Like wise there is not a definitive answer to your question. It really is down to how who ever installed it chose to wire it :cb
But since you are taking back the dimmer why not put the old switch back, and get that working as it should. (By trying combinations) When you have done that take a picture of the connections and try the new dimmer and let us know if you have any problems.
PostPosted: Sat Apr 21, 2018 6:29 pm
I tried doing that last night... Now the light won't switch on!
That still wouldn't help me with where the wire in 'common' should go, or which wires are for the squiggly line with an arrow through
PostPosted: Sat Apr 21, 2018 6:54 pm
Actually it would help. But I can't say any more since you have not got it working yet.
PostPosted: Sat Apr 21, 2018 6:57 pm
How would it help, aside from working out all the different possible combinations?
What should it look like in a normal two way switch set up? Which colours should be in L1 and L2? What about the common?
PostPosted: Sat Apr 21, 2018 7:07 pm
I am NOT being awkward / funny but I have already told you, it is up to how who ever wired it chose to do it, colour choice really is up to them, there is no standard colour code for 2 way switching. hence try all combinations till it works.
The only other suggestion at this time is open your pull cord switch and see how that is connected and connect the switch the same configuration. There should always only be 1 wire in the C teminal
PostPosted: Sat Apr 21, 2018 7:27 pm
Has thanked: 1531 times
Been thanked: 3852 times
:welcomeuhm:
Pics please of the wiring at both switches. I'm sure we can help. Are you sure the dimmer you bought is a 2 way switch ? you said
which suggests a faulty switch or you have only bought a one way switch.
PostPosted: Sat Apr 21, 2018 8:43 pm
which suggests a faulty switch or you have only bought a one way switch.[/quote]
But he already said
So i am waiting for him to put the old one back, get it working then we can take it from there.
Yes pics would help, but if he looks at the pull cord then copies that it is half the battle won
I also never said we can not help
PostPosted: Sat Apr 21, 2018 9:05 pm
How do I insert an image on these forums?
I dont know anything anymore tbf. I’ve had the dimmer switch working, but I took it apart to try and get the two way working again. I’ve put the switch back to a retractive switxh and now it isn’t working. I’m not entirely sure why you’re saying I need to try different combinations, surely if it works it works, and it is the control switch that is needed to be the same?
PostPosted: Sat Apr 21, 2018 10:36 pm
https://scontent.fman2-1.fna.fbcdn.net/v/t1.0-9/31164062_10155987652800465_8291053951565624182_n.jpg?_nc_cat=0&_nc_eui2=v1%3AAeGUSzyOd3mga5qzhRsc1bNp7jl7g1IwCDUCPGb1Y8dQF7aod2WsDuH0hD2XUXrxsK1HN59FJFnsgaUUpxDv-G6P3fhYz3VIEL6EIlnoo-rrpw&oh=c0677c8e1c4a04f5f871490a0cb38534&oe=5B54CBAB
https://scontent.fman2-1.fna.fbcdn.net/v/t1.0-9/31073233_10155987652835465_3038864818566388557_n.jpg?_nc_cat=0&_nc_eui2=v1%3AAeFyzxtvhJfjclu3NYNmZlr_VTLh5NWn0AsbXlIJikQ4NQUga5ZjDmI24opQ2BKcg6pnruc6sF3QjLXZoGu6Uy2wzM5MCw2P7aX9KaJ6WghFEQ&oh=d237f21447464def00ce13fbb688ad03&oe=5B644C53
PostPosted: Sat Apr 21, 2018 10:50 pm
To add images, my signature has a link that tells you how, and how to re size them
PostPosted: Sat Apr 21, 2018 11:33 pm
Hmmmm. It seems I’m having trouble uploading due to pixel sizes :/
I did provide some links in my previous post, however.
PostPosted: Sat Apr 21, 2018 11:43 pm
Sorry but they do not work.
You can also click on the "preview" button to see does everything you have typed work as it should before you press the "submit" button
PostPosted: Sat Apr 21, 2018 11:48 pm
Should work now, hopefully!!
File comment: New switch
File comment: Close up of pull cord
File comment: Wiring at pull-cord switch
File comment: Wiring at switch to be changed.
PostPosted: Sat Apr 21, 2018 11:49 pm
It was more for you to be able to click the links to see the images, rather than have the image embedded in the reply. Uploaded them anyway.
