It is currently Sat Feb 04, 2012 5:06 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Wed Sep 26, 2007 9:48 am
Borders Bodger
Been thanked: 1 times
Quick Question - probably for Hinton Heating ...
When you install the Magnaclean Professinal, would you advise a wrap or two of GAS PTFE tape on the filters threads where the 22mm connection valves fit?
Cheers,
Hoovie.
 Post subject:
PostPosted: Wed Sep 26, 2007 4:54 pm
Shouldn't be necessary on the compression fittings as they are brand new, just cut the pipe and fit your compression joints, isolators etc. You could even look at the website.
http://www.adeysolutions.co.uk/subprofe ... asp?id=248
Good luck, looks a good piece of kit, wonder how much restriction it causes, probably alot if blocked I know, I mean when clean.
Stella Stella Stella oy oy oy
 Post subject:
PostPosted: Wed Sep 26, 2007 5:00 pm
Heres a nice demonstration at plumbworld.
http://www.plumbworld.co.uk/0-15134
 Post subject:
PostPosted: Wed Sep 26, 2007 5:43 pm
Borders Bodger
On the pipe side, non - agreed, but I was thinking more on the magnaclean side as it is made of some sort of carbon-plastic type material.
It supposedly creates no significant resistance in the system and is "50 times less resistive then a traditional/typical (can't remember which) Y-system filter".
It is actually a fairly big canister and I reckon the magnet strenth may be designed to only be able to attract a ceertain maximum amount of sludge so it doesn't block up - I would hope so anyway :grin:
Thought it worth while as the boiler is brand new and want to preserve it as much as possible!
 Post subject:
PostPosted: Wed Sep 26, 2007 5:44 pm
Borders Bodger
just read on website "....These valves have been specially designed for use with Magnaclean and have high quality P.T.F.E seals. "
So, sorted then :thumbright:
 Post subject:
PostPosted: Wed Sep 26, 2007 5:57 pm
Gas/Heating Expert
Been thanked: 4 times
also they have rubber washers supplied!
Hinton Heating
 Post subject:
PostPosted: Wed Sep 26, 2007 6:34 pm
Borders Bodger
to match my rubber head!!
Cheers
