| Author |
Message |
porter
Posted: Thu Oct 27, 2011 8:53 pm |
| Newly registered Member |
Joined: Thu Oct 27, 2011 8:45 pm Posts: 14 Has thanked: 0 times Been thanked: 0 times
I'm planning to install an inline extractor to my shower room, vented to the soffit through the loft space. The inline unit is class 2, with overrun timer and I'm taking live and neutral from ceiling rose. There's no earth in the lighting circuit, but everything looks in good condition.
My plan is to take live and neutral from celing rose using twin and earth (with earth trimmed back) to a fan isolator switch in loft space. Wire to fan via a pull cord switch on the ceiling in the shower room.
Can I split the live before the pull switch to give the fan a live and switched live? And, if so, what's the best way of doing this?
Thanks for your help
| Top |
white pan man
Posted: Fri Oct 28, 2011 12:47 am |
| Senior Member |
Joined: Thu Jul 07, 2011 11:42 am Posts: 773 Location: london Has thanked: 57 times Been thanked: 99 times
As you say you can take L/N from lighting ring ,P/ L to allow fan over run and then take another L from lighting ring and run it through pull switch to form your S/L to fan or use existing S/L to light,if you want fan to operate when light turned on fan will be double insulated and probably will not require a earth attachment
_________________ If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here donnas-dream-house-charity-t52110.html
| Top |
register or
log in
porter
Posted: Fri Oct 28, 2011 12:35 pm |
Thanks white pan man
I want the fan to operate independent of lighting hence the need to split the live to create a switched live. Any idea of the neatest way of doing this? Can I run a single through some trunking?
Thanks again
| Top |
register or
log in
register or
log in
porter
Posted: Fri Oct 28, 2011 10:49 pm |
Thanks Dave...perfect I 'd forgotten about 3 core + earth. As I'm not planning on using the earth (no earth in lighting circuit and fan is class 2), I don't suppose it's permitted to use twin + earth and use the earth as a switched live (using appropriate coloured tape, of course  ) *fully expects to be flamed by people in the know* Thanks
| Top |
register or
log in
OnlyMe
Posted: Sun Oct 30, 2011 4:05 pm |
| Senior Member |
Joined: Sun Apr 24, 2011 7:01 pm Posts: 406 Location: South Yorkshire Has thanked: 7 times Been thanked: 66 times
porter wrote: Thanks white pan man
Thanks again Probably the neatest way would be to use 1mm or 1.5mm "singles" ie 6241Y and 6181Y (google for them and hope that a shed near you sells them by the metre) These are double insulated and do not need trunking.
| Top |
register or
log in
Rich-Ando
Posted: Sun Oct 30, 2011 4:40 pm |
| Pro Sparky |
Joined: Sat Mar 24, 2007 12:24 pm Posts: 6032 Location: Spondon, Derby Has thanked: 85 times Been thanked: 193 times
porter wrote: Thanks Dave...perfect I 'd forgotten about 3 core + earth. As I'm not planning on using the earth (no earth in lighting circuit and fan is class 2), I don't suppose it's permitted to use twin + earth and use the earth as a switched live (using appropriate coloured tape, of course  ) *fully expects to be flamed by people in the know* Thanks no, you must NEVER use the earth wire as anything but the earth. it is highly dangerous to do so.
| Top |
register or
log in
porter
Posted: Mon Oct 31, 2011 9:42 pm |
OK - thought not Thanks everyone for your help - I gonna use 3 core + earth (but trim the earth back 'cus I'm not using it) and use a JB to create the switched live via twin + earth and a pull cord Just got to do it now...
| Top |
register or
log in
Rich-Ando
Posted: Wed Nov 02, 2011 11:02 pm |
| Pro Sparky |
even if you are not using the earth, you still need to connect it at source.
| Top |
register or
log in
porter
Posted: Sat Nov 05, 2011 9:36 pm |
When you say "at source" do you mean at the fan end or the lighting end? In my case, neither have an earth terminal so trimming it back would be safest, I would have thought?
| Top |
register or
log in
Sk_spark
Posted: Sat Nov 05, 2011 9:48 pm |
Joined: Thu Nov 03, 2011 9:15 pm Posts: 26 Has thanked: 1 times Been thanked: 5 times
Source would be source of supply in your case the ceiling rose... even though you may not have any earths in the earth termininal it is still best practice to connect earth in. (Will not actually do anything for your installation as nothing connected), but is there for future use should it ever be required...
Of course you could snip it off (wont effect workings) but is not best practice
| Top |
register or
log in
porter
Posted: Sat Nov 05, 2011 10:08 pm |
The lighting circuit does not have an earth (commonplace in 60s & 70s in the UK). The installation has been tested fine, and the cables look in good condition so I don't intend to rewire
| Top |
register or
log in
Sk_spark
Posted: Sat Nov 05, 2011 10:28 pm |
Agreed loads of houses dont have earths to lights or even earth into consumer unit!!...
I guess best pratice takes into account future ammendments,(ie if metal fitting was installed then earth would be required to that light fitting, if earth has been snipped off then more work than leaving there in 1st place.....)
As stated above snipping wont make any difference to the working of your fan. :)
| Top |
register or
log in
Razor
Posted: Sat Nov 05, 2011 10:32 pm |
| Senior Member |
Joined: Wed Nov 14, 2007 10:21 pm Posts: 5140 Location: Northampton Has thanked: 76 times Been thanked: 372 times
I thought you had to connect the earth at the source to protect the cable just in case someone puts a drill through it. I'm not a sparky but seems right to me
_________________ As always help on here is free, however if you think you have saved a decent sum of money why not click the link to find out about the charity we're currently supporting? A couple of quid makes a real difference. donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Sk_spark
Posted: Sat Nov 05, 2011 10:42 pm |
Absoultly correct.... however in this installation thier is no earthing at source (ie ceiling rose) its is however best practice to allow for future ammendments (Especially as the earth core is already there). (Not a requirement!)
Likewise its not a requirement to use Twin and earth cable to supply the fan, could use singles, as extractor fan doesnt require an earth you would only run over the supply cables anyway (if that makes sense)
| Top |
register or
log in
