It is currently Thu May 24, 2012 12:37 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 10 posts ]
 Post subject: Inspection Access
PostPosted: Mon Oct 24, 2011 10:34 pm
Been thanked: 3 times
Not sure if this is in the wrong forum, I'm sure a helpful Mod will move it to the appropriate area.
I'm about to install a concealed cistern for a back to the wall toilet. The cistern will be built into the void under a set of stairs so where the bog backs onto the void it will be plasterboarded. As the waste out and water input will be in the void I think it necessary to be able to get to the void so how would I build into the plasterboard an inspection access ?
 Post subject: Re: Inspection Access
PostPosted: Mon Oct 24, 2011 10:42 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
Can you get access from the back, otherwise you'll need to form a hatch, plywood and spring clips is about the best
PostPosted: Mon Oct 24, 2011 10:45 pm
Has thanked: 57 times
Been thanked: 99 times
Well would think you would not plaster board behind or above the pan but fit a removable panel for access to cistern/pipe work ect
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Mon Oct 24, 2011 10:53 pm
Thanks Scruff/WPM
No access from the other side of the void.
I want to try and make the hatch as invisible as possible. What are the alternatives to pb behind the toilet that don't look to out of place ?
PostPosted: Mon Oct 24, 2011 11:06 pm
OAP
10mm ply would be the normal.
PostPosted: Tue Oct 25, 2011 8:05 am
Scruff - Is that thae only option. I'm trying to have the room plastered all round so it will look a little out of place with a piece of wood in the middle of the wall.
Is it possible to make a secret access point.
PostPosted: Tue Oct 25, 2011 9:04 am
OAP
Will there be top access, a pic or drawing showing the plan may be be good.
Can't you tile the front/top and have a square that clips in.
PostPosted: Tue Oct 25, 2011 9:12 am
Troll Headbutter
Has thanked: 77 times
Been thanked: 130 times
If it's the back of wall bit, you could use cladding - then you could take it away, should you need to get access.
There are all sorts you can get, in all different colours.
Here is one: http://www.wickes.co.uk/white-ash-effec ... rce=123_74
BG
PostPosted: Tue Oct 25, 2011 1:38 pm
Has thanked: 2 times
Been thanked: 327 times
1) Incorporate a recessed cupboard above the toilet made so that the bottom of it is removable.
2) Incorporate a niche above the toilet and have the shelf part removable for access.
3) Plasterboard wall in sections and each section defined by a shadow bead.
4) Access left open in board and covered with a mirror screwed into place.
5) MDF panel done as in 4.
6) bored now
Good idea to be able to gain access to the flush pipe also.
PostPosted: Mon Oct 31, 2011 10:17 am
I can't fit a cupboard above the toilet as that is where the stairs is.
Don't like the cladding and I'd end up have to break it up to get to the pipe work/cistern etc
So I think I will build a frame wide enough for me to squeeze through and board separately and 'shadow bead' - sounds good, no idea what it means :lol:
Thanks for your input guys :thumbright:
