It is currently Mon Dec 17, 2018 4:57 pm
PostPosted: Tue Oct 24, 2017 7:01 pm
Hello
We have an old megaflo - moved into the property summer last year.
Have had the airbubble recharged (once after moving in & just recently - however it is something I will attempt myself next time pressure drops / tundish drips as seems straightforward).
However the water temp is not terribly hot (I prefer hotter water) - seems to be set at around 50 degrees C on the indirect controller accessible from outside of tank.
I have now set to 55ish (as far as I can tell as not clear from knob where setting mark is !). I think I have turned the correct way as I turned one way until "click" heard, which I assume is the off position, then rotated other way until approx. 55 positioned at 9 o'clock (50 was there before).
Am I doing the right thing ? Will I cause any significant problems turning this up (apart from scolding !) ?
PostPosted: Tue Oct 24, 2017 7:17 pm
Has thanked: 316 times
Been thanked: 960 times
If it clicked when turned anticlockwise then it wasn't up tho the thermostat set temp - It clicks when the contacts open and close.
I presume the heat source is a gas boiler? What is the temp setting on that??
PostPosted: Tue Oct 24, 2017 7:36 pm
No - heating source is the immersion heater controlled by this indirect controller outside of jacket, run on Eco7 electricity at night (boilers are not connected to the tank).
PostPosted: Tue Oct 24, 2017 8:16 pm
Can you post a picture for me please? There would usually be a thermostat on the immersion under the cap
For this message the author Razor has received gratitude : multiman
PostPosted: Tue Oct 24, 2017 9:16 pm
Pics attached (apologies for some distortion as had some trouble re-sizing / rotating them).
File comment: Turned fully anticlockwise with audible "click" near end of turn
File comment: New setting
File comment: Initial setting
File comment: Outside
