It is currently Thu May 24, 2012 12:12 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
PostPosted: Tue Jan 17, 2012 11:24 am
Ive just knocked two bedrooms into one , the small bedroom had a small radiator that I now want to completely remove and blank off , ive got a combi system and the rooms empty now so I can lift the floorboards easily , whats the best procedure to do this
PostPosted: Tue Jan 17, 2012 1:36 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
You'll need to isolate the boiler and drain the system down, you can then cut the pipe under the floor and fit a couple of compression cap ends.
Best to cap it close to where it tees off the main run.
PostPosted: Tue Jan 17, 2012 4:27 pm
Has thanked: 57 times
Been thanked: 99 times
Maybe first work out the heat requirements for the new room area,to see if the one rad left will be sufficient, as if not you could up grade it at the same time as cutting back second rad pipe work,rads are no that expensive ,so worth doing if needed
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
PostPosted: Tue Jan 17, 2012 5:27 pm
Ive got a bigger double radiator to compensate the now larger room
PostPosted: Tue Jan 17, 2012 5:29 pm
Will I have to drain the full system down just for one radiator
PostPosted: Tue Jan 17, 2012 5:35 pm
Has thanked: 9 times
Been thanked: 62 times
im affraid so, unless you want a indoor swimming pool
PostPosted: Tue Jan 17, 2012 7:01 pm
Has thanked: 4 times
Been thanked: 39 times
I am going to have to agree. It can be done if your a competent plumber or heating engineer. :thumbleft:
Your problem is now our problem
PostPosted: Tue Jan 17, 2012 7:09 pm
OAP
With big wellies and a wet vac :mrgreen:
or
freezing kit, not worth the time or money in this case.
PostPosted: Tue Jan 17, 2012 7:59 pm
or
Yep. No wellies, No wet vac, No freeze kit, No problem :huray:
PostPosted: Tue Jan 17, 2012 10:43 pm
moggridgeplumbing wrote:
or
fast hands and a tray?
PostPosted: Tue Jan 17, 2012 10:47 pm
OAP
Do you prefer a hot or cold shower. :lol:
PostPosted: Wed Jan 18, 2012 8:09 am
I pray to Jesus to hold back the waters. Have faith (and lots of towels) :thumbright: :thumbleft:
Users browsing this forum: No registered users and 9 guests
