It is currently Thu May 24, 2012 12:07 pm
PostPosted: Tue Aug 09, 2011 10:24 pm
Has thanked: 7 times
Been thanked: 128 times
I think I might have won this one; took my car to the garage cos it was making a funny noise when braking (had already checked the pads).
Up on the lift and he says I need a new track rod end - couple of hours labour plus parts.
Took it in and later got a phone call - they cant get the track rod off (the inner ball joint) so they have ordered a new inner ball joint as well and will replace them both - OK I say.
Left the car with them overnight and got another phone call to say all the bits are fitted and it's still making a noise - now needs a lower ball joint as well - got the final bill - a shade over £200, which was less than I expected - they've only charged me for a half hours labour. :error: :huray:
I bet they claw it back next time.
PostPosted: Wed Aug 10, 2011 9:43 am
Been thanked: 69 times
Depending on the car the parts should have been less than £50 for track rod end and lower ball joint.
Thats some labour rate they are charging for 1/2 hours labour!
A well equiped garage should be able to change a track rod end in about 5 mins!
1/2 - 1 hour would be normal for lower ball joint.
Changing a track rod end does not involve any "inner ball joints". If the track rod end will not come off you would normally need to replace the steering rack.
Mike
PostPosted: Wed Aug 10, 2011 12:12 pm
It's a VW so the parts tend to be a bit pricey (and got my terminology slightly wrong) : -
Track rod end £51
Inner track rod end £38
Lower arm £58
Plus VAT
Now don't go and spoil it Mike, I was happy with £200. :wink: :scratch:
PostPosted: Wed Aug 10, 2011 5:25 pm
Has thanked: 6 times
Been thanked: 84 times
If it was still making the same noise after the first two parts were changed then I'd say they didn't need changing - so why should you pay for parts you didn't need?
PostPosted: Wed Aug 10, 2011 5:53 pm
It's done 180K miles, there was a lot of movement in the top joint, it definitely needed doing.
(I don't know if it was the same noise, but was told it was still making a noise, it's fine now).
Still smiling. :mrgreen:
