-> Plumbing Forum |
| Author |
Message |
taptaptap Junior Member
| Back to top |
ultimatehandyman Site Admin
Posted: Thu Mar 08, 2007 1:03 pm Post subject: |
Firstly that is a great diagram, well done
I fitted a bath once and had the very same problem.
There should be a tapered washer that seals the pipe into the trap, it is best if this is pushed into place before tightening the nut. The pipe needs to be straight going into the fitting. Check the condition of the washers also. The washer needs to be the correct way around.
If the washer is seated correctly and it is still leaking I would seal the pipe in with silicone sealant, give it a couple of hours to dry and then push the washer up, with a bit more silicone and then tighten the nuts up again.
_________________ DIY | DIY Video |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
| Back to top |
Posted: Thu Mar 08, 2007 3:16 pm Post subject: |
Thank you for your advice. I think a mixture of the two ideas.
1. check/renew washers
2. Fernox
3. Pray !!!
Thanks, I will let you know how it works out.
| Back to top |
