It is currently Wed Feb 20, 2019 1:25 am
PostPosted: Mon Jul 02, 2018 11:23 am
Has thanked: 6 times
Been thanked: 1 times
Hi Folks
I can't get into my downstairs toilet. When the handle is depressed the catch doesn't move far enough across to allow the door to open. Having removed the screws, the handle doesn't want to pull off even with reasonable force. Is there a knack to handles with a built-in thumb lock, or something I may be missing?
I don't have enough room to push anything against the catch and 'walk' it across the last few mm. My last resort will be to cut through the latch. Even that's not straightforward since there's little room for the blade to be inserted beyond the catch, so it would be difficult to cut through the far side.
Any suggestions welcome.
PostPosted: Mon Jul 02, 2018 11:49 am
Has thanked: 643 times
Been thanked: 1815 times
The tube latch is knackered, cheap enough at Screwfix. The problem is the bottom privacy turning handle is held on by a grub screw on the inside. Sometimes you can lever it out if the grub screw is not too tight. If you can get that out then an overturn on the handle with the lock plate unscrewed will give enough movement to open.
If that fails when you turn the main handle it does not give enough clearance of the latch but it will pull it a certain way back. Try a trusty coat hanger wire and bend the end into a right angle hook. As you depress the handle jiggle the catch in the door crack and you might be able to spring it by pulling against the latch cam face.
Try the privacy bolt first :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : stonky
PostPosted: Mon Jul 02, 2018 11:56 am
Has thanked: 410 times
Been thanked: 1500 times
stonky wrote:
Hi Folks
Two slim bladed dinner knives usually works for me. Insert one angled from r to l, lever the latch across a touch to the right and then insert the second knife to the left of the first knife and repeat as often as necessary, you need to keep pressure on the rh knife to stop the latch slipping back whilst the lh knife is inserted.
For this message the author ayjay has received gratitude : stonky
PostPosted: Mon Jul 02, 2018 11:59 am
@dewaltdisney
Many thanks. I'll give that a more concerted yank to start with.
Stupidly, I didn't think to look at one of the other locks in the house which would have revealed the grub screw fixing on t'inside.
PostPosted: Mon Jul 02, 2018 12:00 pm
@ayjay
Yeah that's the 'stepping' technique I wanted to try, but hadn't thought of using dinner knives ... good suggestion.
PostPosted: Mon Jul 02, 2018 4:31 pm
Right.
The bolt was on solid and not going to move.
I screwed the door plate back on for stability, than I tried a couple of knives to walk the latch across, but there wasn't enough purchase on the metal. So I used the same principle, but I first used a 1.5mm bit to break the surface before I walked the latch across each time. I used a scribe and a steak knife point as the two 'walkers' in the end!
One of the two wings on the part that accepts the spindle had broken off so the latch wouldn't fully retract. If it wasn't going to be time-consuming I'd fabricate another one; but looks like it may well be Screwfix for the whole thing.
Thanks DWD and ayjay for your help.
For this message the author stonky has received gratitude : dewaltdisney
PostPosted: Mon Jul 02, 2018 5:17 pm
Has thanked: 1531 times
Been thanked: 3852 times
Ahhh been busy today and didn't see this.
@OP, well done for getting it sorted and be thankful that you weren't locked inside the loo. :hiding:
PostPosted: Mon Jul 02, 2018 5:53 pm
You'd think someone would have written a song about that by now. :mrgreen:
PostPosted: Mon Jul 02, 2018 8:36 pm
Has thanked: 2 times
Been thanked: 16 times
Had a similar problem with our ensuite, unfortunately my wife was stuck in there at the time.
PostPosted: Tue Jul 03, 2018 12:37 pm
Yeah, being locked in would have been a bummer. Shouts of "help" as I got stuck in the tiny square window.
Think I'll fit a fireman's axe; any excuse for a new tool ;)
