It is currently Thu May 24, 2012 10:53 am
 Post subject: Hydraulic Pipe Bender
PostPosted: Fri Jan 20, 2012 10:42 pm
Has thanked: 2 times
Not really sure whether this query should be here or in the tools section, but here goes.
Using a "crossbow" type pipe bender, I wish to put a bend at a specified distance from the end of the pipe so the right-angle is, for example, exactly two metres from the end of the pipe.
Is there a chart or formula for deciding where to commence the bend for various pipe diameters and dies?
The bender.
Thank you
PostPosted: Fri Jan 20, 2012 10:50 pm
Has thanked: 6 times
Been thanked: 84 times
Do it a bit on the long side and then trim it down to suit?
PostPosted: Fri Jan 20, 2012 11:01 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
half the radius of the former.
Best to make a pattern if you need it exact.
What are you measuring, center to end, or back edge to end.
What are you bending still pipe or conduit.
For this message the author thescruff has received gratitude : Kalten
PostPosted: Fri Jan 20, 2012 11:27 pm
Thank you for that.
Steel pipe, 40mm O/D, back edge to end
PostPosted: Fri Jan 20, 2012 11:41 pm
OAP
If you mark a line through the center of the former, the back edge is measured perpendicular to the outside edge of the former. But it's not quite that simple. It should be the center of the former minus half the radius of the bend.
Best to make a template
PostPosted: Sat Jan 21, 2012 1:02 am
Cheers.
PostPosted: Sat Jan 21, 2012 9:51 am
Or, just make it on the long side and cut it down to size.
PostPosted: Sat Jan 21, 2012 10:18 am
OAP
Not always possible Inky Pete, bending pipes has it own problems which any good pipe fitter will know how to solve. :thumbright:
Users browsing this forum: WHSales and 6 guests
