It is currently Thu May 24, 2012 10:47 am
PostPosted: Mon Jul 20, 2009 8:58 am
How do I unhinge (remove) a upcv door from it's frame?
The hinges are like the picture attached - they have a lateral adjustment.
Viewed from the top, there is no alan key socket, but the top of a plastic 'spike' which I am guessing is part of the hinge and the door sits on this.
Do I 'jack' the door up to lift it of its hinges? (there are 3 hinges)
hatter.
File comment: door hinge
 Post subject:
PostPosted: Mon Jul 20, 2009 11:21 am
Has thanked: 134 times
Been thanked: 468 times
unclip the plastic covering the flat section and you should find 2 or 3 bolts to remove the hinge 'you somtimes have to loosten the bolts to adjust the hinge with the allen[hex] key
lightly wedge the door in the centre underneath before loostening the hinges
do not turn the hex bolts whilst removing the door they can be used to adjust the door when refitting
 Post subject:
PostPosted: Mon Jul 20, 2009 11:26 am
Has thanked: 80 times
Been thanked: 38 times
You can lift it up off hinges, easy to do on your own, easier if somebody helps putting it back though.
This is providing you have enough clearance at the top.
Going to have to take mine off soon to do some painting as theres not much room hinge side.
 Post subject:
PostPosted: Mon Jul 20, 2009 2:12 pm
Going to place tomorrow. Will see how it goes.
Hatter[/quote]
 Post subject:
PostPosted: Wed Jul 22, 2009 11:42 pm
Door lifted off hinges.
Hatter.
Users browsing this forum: No registered users and 8 guests
