It is currently Thu May 24, 2012 10:46 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 11 posts ]
 Post subject: How to touch up screed
PostPosted: Fri Sep 23, 2011 2:30 pm
Has thanked: 80 times
Been thanked: 38 times
Have lifted a carpet and on sweeping up a couple of bits have crumbled and lifted and have left a little crater (about 50p size/slightly bigger).
Before new underlay goes down and carpet anything i can use to fill the gaps?
I have the basics at hand, sand/cement/fibres/few other items that might be able to be used. But don't want to put a whole layer across the floor.
PostPosted: Fri Sep 23, 2011 6:44 pm
Has thanked: 58 times
Been thanked: 272 times
Gripfill, caulk, anything that will be dry before the carpet arrives. 2 part wood filler etc.
Sand and cement will not always bond if it is too thin. Cement on it's own is much better.
PostPosted: Fri Sep 23, 2011 7:15 pm
Carpet won't be for a while, so have plenty of time. Just wondered what was the best solution?
PostPosted: Fri Sep 23, 2011 7:19 pm
Has thanked: 2 times
Been thanked: 327 times
Rapid setting cement.
PostPosted: Fri Sep 23, 2011 9:09 pm
I don't have any but don't mind getting a bag, would i do a wet mix and brush it in or a thick one?
PostPosted: Fri Sep 23, 2011 9:28 pm
wet mix will be fine. it won't be wet for long though lol
PostPosted: Fri Sep 23, 2011 9:34 pm
Has thanked: 15 times
Been thanked: 161 times
Get a small bag of self leveling, dampen the areas then apply.
PostPosted: Fri Sep 23, 2011 11:12 pm
Has thanked: 144 times
Been thanked: 9 times
I bought some quick set cement, mixed it with more water than recommended, then poured it into the holes. I waited for it to stiffen, then used a shoe to smooth it. Totally non kosher, but it worked.
PostPosted: Sat Sep 24, 2011 8:06 am
Is self levelling normally this expensive.
http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=10487644&fh_location=//catalog01/en_GB/categories%3C%7B9372016%7D/categories%3C%7B9372048%7D/categories%3C%7B9372249%7D/specificationsProductType=floor_levelling&tmcampid=4&tmad=c&ecamp=cse_go&CAWELAID=350176962#BVRRWidgetID
PostPosted: Tue Sep 27, 2011 10:42 am
If i went for the quick dry cement, would you think it would be fine to do now, although carpet may not get down for another month or so? Or should i leave it to just before the carpet goes down?
It does and will have light traffic over it until carpet is fitted.
PostPosted: Tue Sep 27, 2011 12:16 pm
Been thanked: 26 times
Now will be fine, its not meant to be left as a finished surface though.
So either cover it up, or do it a few days before the carpet goes down.
With carpet you could lay it up to the next day. You only need to leave 1mm per day if you are installing something thats not breathable. E.g. laminate, karndean or ceramics.
My project blog - Check it out
For this message the author Crooksey has received gratitude : lagi
