It is currently Fri Mar 22, 2019 2:26 am
PostPosted: Wed May 02, 2018 5:28 pm
Has thanked: 130 times
Been thanked: 3 times
Hi All,
I am not sure how to take off the Radiator grille off, as i need to take of for cleaning.
I think this radiator is Henrad or from B&Q not sure.
It has plastic half round on the top and bottom and i can see little hooks on the side top edge of the grille from inside.
Your advice much appreciated.
PostPosted: Thu May 03, 2018 5:59 am
Has thanked: 231 times
Been thanked: 186 times
The top should lift off and the sides will then lean out. The sides aren't fully removable due to the valves but there'll be enough room to clean.
PostPosted: Thu May 03, 2018 6:30 am
Has thanked: 410 times
Been thanked: 1517 times
I have something similar, can't see from the pics if it's exactly the same.
With mine, first lift the sides to the correct position and they will remove completely, then the top just lifts off.
PostPosted: Sat May 05, 2018 5:26 am
Hi All,
Thank you for your replies.
I managed to take it off and the side panel did not move up , but I managed to take off the top cover off.
It had round plastic connector and connected to the top rounded shape and the ends they were hooked in to with 2 lugs. I don’t why they had to go over the top with this.
The other radiator grilles in the house were easy to take off, like ajay said, I only had to lift the side and the top just easily comes off by pressing the side panel from top to disengage from the 2 hooks connected to the top grille holes.
Side panel just moved outward to side from top.
Thanks Guys.
