It is currently Sat Jan 20, 2018 3:29 am
Visit Thermo worx
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
PostPosted: Fri May 26, 2017 9:06 am
Been thanked: 1 times
I'd like to add lights on top of a cupboard with which has down lights affixed.
See the attached images for what's happening on top of the cupboard at the moment. Is it simply a case of wiring up my new lights to the white thingy?
Thanks for your help!
File comment: The white thingy
PostPosted: Fri May 26, 2017 7:16 pm
Has thanked: 1358 times
Been thanked: 3511 times
:welcomeuhm:
Impossible to say from those pics.......Buuuut what lights have you got ? Selv ? (link?) most likely you'll have to add a cable to the junction box with an inline switch.
For this message the author wine~o has received gratitude : sajeel
PostPosted: Fri May 26, 2017 8:25 pm
Has thanked: 327 times
Been thanked: 1694 times
The power pack has a maximum output of 70W
Add up the power rating of all the bulbs currently connected to see how much spare capacity you have. Assuming there IS spare capacity you can add more bulbs up to the theoretical power limit - although it's not recommended to fully load it as some spare capacity means longer life.
If you find you can add safely then simply connect at the chock-bloc - although changing that to a pair of 4-way WAGO connectors would tidy it up somewhat.....
For this message the author kellys_eye has received gratitude : sajeel
PostPosted: Sat May 27, 2017 5:56 pm
Thanks very much! Can I use the existing chock bloc or do I need one with more slots free?
For this message the author Dazjohnson has received gratitude : sajeel
PostPosted: Sat May 27, 2017 6:05 pm
Use the existing one if you wish - the more wires in it the more difficult it is to get a secure connection though. Purists :mrgreen: would use the WAGO stuff but I confess to using chok-blok in that manner myself in the past......
PostPosted: Sat May 27, 2017 10:19 pm
Awesome thanks. Sorry, last question. What if I wanted to hookup a led light strip to the chock bloc? Most of them seem to be usb powered.
Eg TN Cow LED Strip Lights Kit 16.4ft/5M Flexible Waterproof IP65 3528 RGB 300 LEDs 12v Light Full Kit RGB LED Strips Lighting With 44Key Mini IR Remote and DC 12V 3A Power Adapter Supply for DIY Party Decoration Home Kitchen Cabinet Closet Party KTV Studio Wedding Girls Room Decoration and Indoor Outdoor Use https://www.amazon.co.uk/dp/B06XJS7RZS/ref=cm_sw_r_cp_apa_vZEkzbT3JM5QF
PostPosted: Sat May 27, 2017 10:26 pm
The strip you (sort of) link to is powered from 12V and will work using the supply you already have - assuming you have the spare capacity..... the LED strip is rated at 36 watts.
If the lights you have PLUS the 36W LED strip add up to more than 70W you can't do it.
PostPosted: Sun May 28, 2017 8:53 am
Sorry my question wasn't very clear, it was more how would I go about hooking that up. Would I need a special adapter or something?
PostPosted: Sun May 28, 2017 9:48 am
No - they usually come with a power supply - your link shows it as the black box with a mains plug - but you can discard the mains power supply and chop the cable off the OTHER END of the power supply (where it has a flying lead going to the LED strip) and wire that up to your chok-blok for the 12V you need.
The pic below shows the black power plug - Maplins will supply a similar plug if you don't want to butcher the mains power supply and you know how to solder....
PostPosted: Sun May 28, 2017 9:54 am
Has thanked: 36 times
Been thanked: 1153 times
It would be better if you were to use the power supply that came with your LED strip.
The reasons are:
It is plug and play
You will not have to worry about the rating of the "transformer" (Kellys Eye called it powerpack)
You cut the mains plug off and connect the now plug less lead to the same place as the power supply is connected.
PostPosted: Sun May 28, 2017 6:09 pm
Brilliant, thanks both. Just to confirm I'm cutting it in the red line in the attached?
PostPosted: Sun May 28, 2017 7:08 pm
:welcomeuhm: Noooooo don't cut it there. You have a dedicated driver for your led strip.
You have a junction box before the transformer (round box)
lecky off remove the central screw and a pic of the wiring inside please.
PostPosted: Sun May 28, 2017 7:58 pm
:withstupid: But you want to cut the plug off. Close to the plug, then wire it into the junction box. (Picture still required though)
and since you can draw lines on pictures, draw another one where you intend to cut the plug off. (You can move a coloured line, you can't "stick" a cable back)
For this message the author someone-else has received gratitude : sajeel
PostPosted: Sun May 28, 2017 9:51 pm
Kelly's said `you can discard the mains power supply and chop the cable off the OTHER END of the power supply (where it has a flying lead going to the LED strip) '. Is this not where I drew the line? But you guys are saying wire it in to transformer and not the chock bloc like kellys is saying?
Why is one easy better than the other? Or have I got the wrong end of the stick?
PostPosted: Sun May 28, 2017 10:12 pm
You have several "problems"
1) You need to calculate the total existing load on the "transformer" to figure out is there enough capacity to add your LED strip.
2) Since your LED strip comes with a dedicated power supply, why not make life easier by using that and connecting it to the mains.
3) Never said wire it to the transformer. Did say wire it to the junction box / same place the power supply is connected.
4) One is easier / less risk and better than the other
