It is currently Sun Dec 09, 2018 11:58 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Sat Oct 21, 2017 7:11 pm
Has thanked: 12 times
Been thanked: 3 times
It's very likely I will lose money on it but that's OK. It's an idea I've dreamed of as a child.
The boxes will be easly customisable and will accept any parts when most cases on the market are designed for very specific parts.
My wife would also like to make bed headboards so she is very happy and supportive with my new hobby.
PostPosted: Sat Oct 28, 2017 9:39 pm
First box made of scrap wood done. Looks bad but now I understand how to use tools and can produce nicer ones. I decided to use dowels.
I've also done a simple test to check how inaccurate my cheap mitre saw is.
Without any adjustment it cut a perfect little frame. I'm surprised and happy with it. :huray:
It's not even glued yet. Just laying lose and holding shape.
PostPosted: Sat Oct 28, 2017 10:44 pm
Has thanked: 695 times
Been thanked: 1999 times
yes your getting there
good luck and dont make to many at one time until you have a quality and design you know is selling
PostPosted: Thu Nov 02, 2017 9:51 pm
First box assembled but not finished yet.
I have small problem with quality. Cheap wood seems to change shape after gluing and I sometimes get gaps like on the second picture.
What would you suggest to eliminate these gaps?
Also what would you suggest for wood finish? I like the look of burnt wood but don't have skills to do it consistently.
PostPosted: Fri Nov 03, 2017 10:11 am
you should use dowels and a jig so they are hidden
random example here
https://www.amazon.co.uk/Silverline-508 ... B000LFXJ9S
dowels are about 2p each
random link
https://www.amazon.co.uk/Silverline-868 ... B000OIJHN4
and this glue
https://www.toolstation.com/shop/p61864?searchstr=d4
PostPosted: Fri Nov 03, 2017 11:27 am
Has thanked: 1171 times
Been thanked: 1067 times
You need to clamp the frames up as well until the glue has properly set.
PostPosted: Fri Nov 03, 2017 12:10 pm
Has thanked: 619 times
Been thanked: 1771 times
Just mess with your head see https://www.youtube.com/watch?v=CMXjuXzfwjs
I use this for making drawer boxes and the like it gives a clean corner.
Painting with BIN
PostPosted: Fri Nov 03, 2017 6:53 pm
Has thanked: 751 times
Been thanked: 833 times
The SSL certificate of the website you posted the images has expired, but even accepting that I cannot see anything. And even if they worked, at some point you will delete them and this thread will be meaningless. See this link posting-pictures-t24811.html for how to post images on Ultimatehandyman.
PostPosted: Fri Nov 03, 2017 10:51 pm
random example here
random link
and this glue
Thanks for the glue recommendation. 10 minutes sounds impressive.
The visible dowels is a test. I already have standard dowels and a jig/marker.
Just wanted to check how to make it easy and potentially look good. I will cut them off.
Something like this:
Imagehtthttps://youtu.be/mbbwo9unFwQ?t=1m1s
dewaltdisney - thank you for such a helpful video :)
PostPosted: Fri Nov 03, 2017 10:52 pm
random example here
random link
and this glue
PostPosted: Fri Nov 03, 2017 11:16 pm
you will have to leave it for about 2 hours to dry in a say 18 degree room perhaps 90 mins in say 22 degrees but perhaps 3 or 4 hours at say 14 degrees
all depends on stresses clamped in to joints
if good close fits
all above are before further working like routing cutting planing etc
just laying down carefully will be ok in half the time as long as no large gaps being held closed with clamps :lol:
PostPosted: Fri Nov 24, 2017 5:05 pm
Had a break from making my boxes.
Now I need to decorate them and my challenge is end grain and glue.
If I put stain it look great on sides but makes the glue very visible and end grain looks very dark.
How would you finish this pine box?
PostPosted: Fri Nov 24, 2017 10:18 pm
on a 40mm wide bit off wood you need no more than a bead off d4 glue in two lines about 10mm from each edge and no more than about a 1-2mm bead
you must wipe clean then use a wettish bit off kitchen roll then a dry bit for any ooze
