-> Carpentry/Joinery Forum |
| Author |
Message |
Jun Junior Member
Posted: Wed Aug 22, 2007 1:58 pm Post subject: How to cut..? |
Hello~
I'd like to cut a timber(4X2) which is located between other two timbers.
There're about 2-3cm gap between.
It's absolutely impossible to use a normal saw.
What kind of tool do I need to use to cut middle timber?
Many thanks! |
| Back to top |
ultimatehandyman Site Admin
Posted: Wed Aug 22, 2007 4:35 pm Post subject: |
It sounds like you might need a chain saw for that jun, or you could use a normal hand saw, but it will not be easy! _________________ DIY | DIY Video |
| Back to top |
Jaeger_S2k Senior Member
Joined: 19 Nov 2006 Posts: 2786 Location: North West, England, United Kingdom
Posted: Wed Aug 22, 2007 4:42 pm Post subject: |
Can you take a picture?
It'd help a lot.
And where are you from? _________________ Jaeger.
FSBF |
| Back to top |
big-all Pro Carpenter
Joined: 16 Dec 2006 Posts: 2775 Location: redhill surrey an auld reekie laddie
Posted: Wed Aug 22, 2007 4:58 pm Post subject: |
not actualy shure if i understand this one
if you have 3 bits of timber in a parralel line with the 2" part showing and a gap off 1" between and you want to cut from the 1" gap accross the timber you could use a reciprical saw or a jigsaw with extended blades
if you have the restriction of a wall behind and its nailed in the ends of the wood you could possible use a bi-metal or progresive blade to cut through the nails and cut at the very end off the wood along the edge of the other bit its butted up to
or even a hacksaw blade wrapped one end with loads of tape as a handle and the teeth pointing towards the padded end
or you could use a normal sharp wood blade in your jigsaw this will cut soft nails no probs
then finnish the last 1/3 depth with the hacksaw blade untill your through the nail in the back 1/3 _________________ we are all ------------------still learning
| Back to top |
handimick Junior Member
Joined: 19 Aug 2007 Posts: 26 Location: Wolverhampton
Posted: Wed Aug 22, 2007 6:44 pm Post subject: |
If it were me I would drill a series of holes and finish with a chisel... :grin: _________________ Tea, milk and no sugar... |
| Back to top |
