It is currently Fri Apr 20, 2018 9:22 am
PostPosted: Tue May 01, 2012 5:04 pm
Has thanked: 4 times
Good afternoon guys.
I try to convert my existing standard light in the toilet to two downlight, but need some tips.
In my "rose" I have 3 red, 3 black and 2 earth cables.
Then there is 1 white wire with two cables - blue N & brown L going to the light bulb.
Please note that I have connected 1 downlight with this white wire using chockbox.
My question is:
Can I simply connect the second downlight with the same white cable (using junction box)?
Or should I connect the second one from the ceiling rose where the white wire is connected?
How to make another connection?
Please dont think that I have ignored other forum topics and I havent search for an answer.
Ive found "how to fit downlights"
http://www.ultimatehandyman.co.uk/how_to_fit_downlights.htm
But on the attached photo there are only two grey 1.5mm2 wires going from ceiling.
Also I found a tip that each downlight should be connected to each other.
Im just not sure can I use this white soft wire... and I dont want to mess up my electric circuit.
Any tips and advices will be much appreciated!
Lucas
PostPosted: Tue May 01, 2012 7:07 pm
Has thanked: 1404 times
Been thanked: 3629 times
Sorry, either your terminology is wrong or your wiring...
You should have 3 earths assuming a standard ring.. may help if you can post pics, there is a difference between "Cables" and "cores"
EDIT...Manners................... :welcomeuhm:
PostPosted: Tue May 01, 2012 7:38 pm
Good evening guys.
Just ignore my first post, yes "wine~o" I have used confused terminology...
Apologies for my mistakes.
I was in rush and havent written it carefully.
My post should look like that.
In my "rose" I have 3 red, 3 black and 3 earth cores.
Then there is 1 white 0.75mm2 2 core flex cable going to the light bulb.
Please note that I have connected 1 downlight with this cable using chockbox.
My question is:
Can I simply connect the second downlight with the same flex cable (using junction box)?
Or should I connect the second one from the ceiling rose where the flex cable is connected?
Im just not sure can I use this 2core 0.75mm2 cable... and I dont want to mess up my electric circuit.
Lucas
PostPosted: Wed May 02, 2012 12:52 am
Ok... 91views on this post but no reply, no help, tips, nothing....
Ive managed to finish my job without anybody's help.
For people with similar problem here is how to do it:
Switch off the mains from the circuit you work with then:
1. uncover CEILING ROSE
2. find flex cable with two wires N - neutral- blue and L - live- brown.
3. Get a new 2 core 0.75mm2 flex cable for small amount of downlights (in my case 2), for more I reckon you need to have minimum 1mm2 flex cable.
4. Replace this cable (you dont have to if you are happy with existing length) and connect it excactly the same way as it was.
See rose diagram:
http://*Alert moderator- please report this post*/projects/electrical_safety.htm
5. Then get a chockbox and join these two wires into L and N sections, and simply put two 0.75mm2 (or more if you need more) cables on the other side of your chockbox. You should have then 1 blue and 1 brown on the top, and then 2 blue and two brown wires.
And this is it.
Get your halogen connector and connect it with each 2core cable (OF COURSE IF YOUR HALOGEN IS DOUBLE EARTHED)
In case you get 3 core connector, then you have to connect your E wire to your ceiling rose earth E section.
Hope its helpful.
Lucas
PostPosted: Wed May 02, 2012 3:08 am
Been thanked: 37 times
not even going to comment on above. then again who needs earth protection
PostPosted: Wed May 02, 2012 11:16 am
My downlights DO NOT need earthing.
Its written in manual,
the cable is double insulated so NO CONNECTION should be made to earth.
PostPosted: Wed May 02, 2012 3:47 pm
Approved Electrician
Has thanked: 159 times
Been thanked: 547 times
You are a fool with a bad attitude.
PostPosted: Thu May 03, 2012 1:09 am
Who are you then? and the person above, who instead of helping, correcting if Im wrong (Im not an electrician! Just learning!)
calling me fool?
This forum I think is for people like me and others who need to understand how to do things right.
Is this forum for ONLY PRO TRADE electricians who can just accusing or ignoring others in this case its me???
So just think why is this forum for? and who for?
Bad attitute is not to help someone who ask for it.
At the moment you and the other guys showing me two fingers.
Forum Rules
We want to continually grow and keep this forum as a place where members can learn, share, help each other.
I just don't think it's clear enough for all forum users. Shame.
PostPosted: Thu May 03, 2012 1:24 am
What I was against was that of a post u made that says don this way I solved the problem, but the way you did could put lives in danger at a later date as spark following would assume there work on an installation thats done to standard, what you have suggested is not and could become dangerous.
My qualification I have a BENG (hons) in electrical engineering
I have no problem helping, but patience is a vertue, I appoligise I missed ur post be as u have seen we did in the end.
regards
John
PostPosted: Thu May 03, 2012 1:28 am
Ive just found this:
"The downlights that I am fitting do not require an earth and so I have terminated the earth into a spare terminal. Do not cut the earth off as it may be needed if you ever replace the lights. "
It's just confirming my words above.
Regards
Lucas
PostPosted: Thu May 03, 2012 1:36 am
regards
John
Hi John,
Ive respect your qualifications I wish I had your knowledge but I dont, that's why Im here to find people like you who can correct my mistakes.
After reading all my messy messages can you confirm that my installation is fine then?
Regards
Lucas
PostPosted: Thu May 03, 2012 1:47 am
http://www.ultimatehandyman.co.uk/how_t ... lights.htm
Regards
Lucas
Ok you should not use the flex but add 1mm-1.5mm twin and earth cable, remove ceiling rose completely and using a 15a 6 way junction box put the 3 reds together, 3 earths and the two blacks, (neg) the remaining black is switch live return and was the one going to the red/brown cable in the rose, (should have a red sleeve on if not add either brown tape or sleeve), then add your new cable brown to the black switch live, blue to the two blacks, (neg), earth to the earths, then supply your first down light from this cable terminating all three wires in a jb include the next cable for next downlight and the flex/cable for that downlight, the most important cable you are terminating is the earth.
Regards
John
Edit: for info earth is what protects the user, say in 6 years someone decides to fit metal clad heat lamp guess what the earth is there ready for use, thats why the earth is so important
For this message the author gasspark has received gratitude : ragged13
PostPosted: Thu May 03, 2012 3:09 am
Regards
John
Edit: for info earth is what protects the user, say in 6 years someone decides to fit metal clad heat lamp guess what the earth is there ready for use, thats why the earth is so important[/quote]
If you could look at the photo (no.10)
Terminating the earth means in this case to screw the earth into spare terminal right?
That why I was so confused.
BTW
The manual from my downlight says to use 1.0mm2 flex cable. It wasn't my invention.
Thanks for your tips! Really appreciate.
Regards
Lucas
