It is currently Thu May 24, 2012 10:23 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: HOW?
PostPosted: Wed Jan 25, 2012 7:27 am
Has thanked: 1 times
Been thanked: 7 times
dave.m wrote:
A lot of saws have a right angle between the handle and blade.
dave
dave you should be ashamed at the very suggestion, i havnt yet found an accurate saw that has a square edge :roll: . Possibly the edge of a cereal box might give you a better reading. lol :dunno:
no in all seriousness, the answer of getting one reading (whether its a square or level) and the flipping it round to see if it reads the same way, is the easiest and most accurate way of checking if either are true. :huray:
PostPosted: Wed Jan 25, 2012 8:38 am
Has thanked: 58 times
Been thanked: 272 times
To get a right angle, I tend to use a roofing square unless it is over a larger area, in which case I often use a sheet of plasterboard ,or other sheet material which I usually have to hand. For much larger areas I use a tape measure and Pythagoras theorem
For levels, I check the vertical against a plumb line. Horizontal, I check against another level I have which I can prove is accurate because it reads the same when reversed.
PostPosted: Thu Jan 26, 2012 12:58 am
Has thanked: 7 times
It's more or less conclusive then, that for No2....trueness of a right angle....it's the 3,4,5 rule.
I like the 'floating the spirit level in the bath' for No1.....Accuracy of a spirit level.
I did come up with another potential or two for Q No2....
Hang the level from a nail (if your level has a centre hole at either end) so that it hangs freely, or loop some string through it and hang it like a plumb bob.
I guess doing this would work for checking the vertical bubble, and the 'water'' methods for the horizontal bubble.
well...here's the result!
1st place goes to....(drum role)........JoinerJohn. :salute:
Thanks for taking the time to respond chaps....quite good for the brain matter and curiosity factor.
It did prompt me to look up 'how the ancients measured angles and levels'.....
The Egyptian Groma, and the Greek Dioptra.
