It is currently Thu May 24, 2012 10:09 am
PostPosted: Wed Jan 18, 2012 4:04 pm
Hi, I'v put in a 3 gang 2 way light switch, so that I can wire up a porch light. I'v already wired in the hall and landing light and they both work, but am having problems getting the porch light to work it has a three wire cable Brown, Blue, and yellow/green. I wired the blue wire to L1 and the brown to the com in the spare gang and there is no power going to the porch light, I'v tried looping a wire from the com to the main live wire, and this didn't work also tried linking all coms on the gang and this also didnt work after doing these I tried the hall and landing lights and they still worked can someone please explain where I'm going wrong :-$
PostPosted: Wed Jan 18, 2012 4:08 pm
Has thanked: 166 times
Been thanked: 612 times
You need a neutral fed to the outdoor light... You are very unlikely to have one at the switch...
PostPosted: Wed Jan 18, 2012 10:28 pm
Hi, how do I go about feeding a neutral to the outside light?
PostPosted: Thu Jan 19, 2012 7:57 am
If you are lucky, then all your wiring will be ron in conduit (Unlikely) in which case, you can just run a Neutral from the ceiling rose to the switch., and from there to the light..
Otherwise you'll need to be chasing out walls to run the neutral..
Users browsing this forum: No registered users and 6 guests
