this will help you check if the bearings are worn i will need the model number to tell you the Exact ones , i will put a link below to take you to the bearing section on our site, then put your model number in and find the ones you need all the best paul
<embed src="http://www.ultimatehandyman.org/flvplayer.swf" quality="high" width="450" height="367" name="VideoPlayer" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" flashvars="file=http://www.ultimatehandyman.org/uploads/ln5zymnYCA2UIsARNcfh.flv&width=450&height=367&overstretch=true&logo=http://www.ultimatehandyman.org/image_s/playerlogo.png&link=http://www.ultimatehandyman.org&linktarget=_blank&showdigits=false&backcolor=0xFFFFFF" wmode="transparent" border="0"></embed>
Click below for bearing kits
http://www.apart4u.co.uk/acatalog/Washing_Machine_Bearings.html
what a bearing set looks like.
