It is currently Thu May 24, 2012 10:02 am
PostPosted: Wed Dec 07, 2011 3:18 pm
Has thanked: 12 times
I have a dishwasher Hotpoint/Aquarius DWF40.
W hen putting it on this morning the start alarm sounded a bit different and the machine just stays in pre wash mode. It isn't filling with water either, yet the water supply is ok in the rest of the house.
Anyone got any ideas?
cheers
PostPosted: Thu Dec 08, 2011 1:39 am
Has thanked: 57 times
Been thanked: 99 times
could be a faulty inlet solenoid on the cold feed maybe
If you have found help on the UHM's forums,why not help out the UHM's Nominated Charity,find out more here
For this message the author white pan man has received gratitude : geezer1
PostPosted: Thu Dec 08, 2011 2:07 pm
Thanks for the reply White pan man
So any tips that don't cost the earth on how to check this inlet solenoid out?
cheers
PostPosted: Thu Dec 08, 2011 8:02 pm
Has thanked: 7 times
Been thanked: 17 times
Different machine similar fault. Used to strip the machine down to fix it. When it happens now I open the door remove the bottom tray and give it a clout (flat of hand) in the vacinity of the water inlet. Works every time. In our machine there's a small thin, plastic water tank in this location between the two skins with a float valve in it which sometimes sticks in the up position when it should be down. Worth a try
Trevor
Users browsing this forum: Exabot [Bot] and 2 guests
