-> Plumbing Forum |
| Author |
Message |
Staf4d Junior Member
Posted: Sat Dec 01, 2007 1:09 pm Post subject: Hot Water Tank |
It takes hours for the hot water tank to heat up. It is heated by an electrical immersion heater and probably controlled by a thermostat, which I suspect is the problem.
I do not know how to remove & replace this thermostat as there do not seem to be any screws holding it. However it is mounted on a large circular plate which is bolted on the underside of the cylinder.
Can anyone help? |
| Back to top |
Hinton Heating Gas/Heating Expert
Joined: 16 Jan 2006 Posts: 4296 Location: Bournemouth
Posted: Sat Dec 01, 2007 5:54 pm Post subject: |
could you post a pic please. _________________ www.hintonheating.com
| Back to top |
Posted: Mon Dec 03, 2007 1:59 pm Post subject: Hot Water Tank |
Thanks Hinton for responding.
I will not be able to get pictures until mid next week as I will be away. Hope that is OK.
Thanks |
| Back to top |
