Ultimate Handyman Home
Hot water shuts down boiler
Post new topic   This topic is locked: you cannot edit posts or make replies.   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers
samtheman1
Junior Member
PostPosted: Thu Oct 02, 2008 9:11 pm    Post subject: Hot water shuts down boiler Add User to Ignore List Reply with quote
Hi to all,i have a ravenheat rsf 820/20 combi boiler,the problem is after i run a bath and turn off the tap,the overheat stat kicks in and shuts off the gas valve.Also when the tap is opened again the water is very very hot.Everything works fine when the heating is on.Any ideas please. Bang Head
Back to top
thescruff
PostPosted: Thu Oct 02, 2008 9:40 pm    Post subject: Add User to Ignore List Reply with quote
Could be the domestic hot water control stat, but really you need an RGI to check it out .
Scruff
Back to top
samtheman1
Junior Member
PostPosted: Fri Oct 03, 2008 10:34 am    Post subject: Add User to Ignore List Reply with quote
Thanks for reply, the stat seems to be working ok,it clicks on and off and the flame goes up and down,scratching my head at the moment.
Back to top
Display posts from previous:
Post new topic   This topic is locked: you cannot edit posts or make replies.    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum -> Central Heating & Boilers All times are GMT
Page 1 of 1
