www.ultimatehandyman.co.uk Forum Index -> Plumbing Forum
-> Central Heating & Boilers |
| Author |
Message |
iainiow Junior Member
Joined: 03 Jan 2007 Posts: 38 Location: Isle of Wight
Posted: Thu Aug 30, 2007 11:25 am Post subject: hot water (or not!!) |
I have moved in to a house that has a combi boiler - it is a sealed system and therefore has no tanks etc. the pressure gauge is low - would this affect its ability to supply hot water through the taps? i get hot water, but it fades to cold fairly quickly.
running a bath will result in a luke warm result as it fades between hot and cold so often. |
| Back to top |
ultimatehandyman Site Admin
| Back to top |
Posted: Thu Aug 30, 2007 11:54 am Post subject: |
| righto, thanks for the tip i will give it a go! |
| Back to top |
Posted: Thu Aug 30, 2007 12:00 pm Post subject: |
It's a good idea to top up the combi to the pressure that your manufacturer recommends and then bleed the radiators and then check the pressure again. If there is lots of air in the radiators the pressure will drop in the combi when you bleed it and it will need topping up again. _________________ DIY | DIY Video |
| Back to top |
