It is currently Wed Jan 17, 2018 3:17 pm
Visit Thermo worx
 Post subject: Honeycomb Plasterboard
PostPosted: Mon Dec 03, 2012 11:22 am
Has thanked: 11 times
I've just let the plumber into the bathroom to start stripping out the old bath etc. I was planning on ripping out the old plasterboard (and attached tiles) and re-plasterboarding half the room. The plasterboard in this part of the room, next to the bath, looked pretty damaged under the bath, probably from the old leaking seal around the bath. I saw expecting stud work behind the old boards but we've discovered plasterboard with honeycomb cardboard behind it (paramount board according to google?) with no signs of stud work, just a 40mm wooden outer frame.
This short wall is an internal partition between the hallway and bathroom. Am I likely to find the other walls in the bathroom likely to be constructed the same? The longest wall that needs work is the plasterboard wall dividing us from next door, which I really don't want to mess with if i'm going to unravel a loads of problems.
I'm a DIYer, so any advice from other DIYers or trade that have come across this setup before?
PostPosted: Mon Dec 03, 2012 5:42 pm
Has thanked: 349 times
Been thanked: 1293 times
If one wall is a Paramount partition it's likely that any other internal non-load bearing walls will be.
A party wall between your house and next door is likely to be brick or block and will probably be dot and dabbed with p/b.
You may be able to see what the construction of any particular wall is if you remove the skirting boards, you might need to have a dig around and remove a small amount of p/b.
For this message the author ayjay has received gratitude : mikedigitales
PostPosted: Mon Dec 03, 2012 6:49 pm
Thanks Ayjay, I've done a bit of exploring and you were dead on. Going to build a new stud partition wall to replace the paramount and looks like I'll be learning to dot dab the other wall. Anyone have a good step by step or tips for the dot dab?
PostPosted: Wed Dec 05, 2012 1:43 pm
Has thanked: 5 times
Been thanked: 3 times
If the surface is flat enough, then place dabs of driwall adhesive onto wall at around 400mm apart at even thickness and lift board onand push in gently, then level it to same levels as existing walls and remember to pack it up till it sets so it doesnt slump. Also dry run your plasterboard before you fix with adhesive to avoid an problems
PostPosted: Thu Dec 06, 2012 1:08 pm
Has thanked: 10 times
Been thanked: 48 times
Search youtube for dot and dab, there are some good videos with the basics.
For this message the author dandan has received gratitude : mikedigitales
