It is currently Fri Apr 19, 2019 4:01 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
 Post subject: Home office over garage
PostPosted: Mon Oct 03, 2016 8:50 pm
Has thanked: 11 times
Been thanked: 4 times
Hi all, just about to buy a house, needs a bit of work, but most interested in putting an office over the garage, and checking if I need to consider anything extra! How much regs will affect it etc.
I never done anything like this before, so hoping for some guidance and some tips,
Essentially its a double detached garage. It's brick outside and blocks inside,and there is a steel joist across the width supporting the wooden joists forming the floor above.
The loft area is already boarded (so would want to pull up and insulate), but other than that it's just the rafters with no props or ties. There is also a relatively small velux window there, and some steepish stairs (that effectively take out of of the parking bays).
The big negative is the garage internal dimensions are just 4.90*4.90, and think the max height in the loft is around 2.10 (estimated) at the peak, so the useable standing area will be limited, hence the idea of a home office rather than anything more adventurous (like a bedroom)
So guessing I need to insulate as a starter, and get some decent lighting in.
Would I be best putting in a partition type wall with door at the top of the stairs, or is there another elegant solution (some sort of hatch?), mainly to help with warmth! Talking of which is it worth trying to insulate the actual garage area at all (reducing drafts round the doors and some insulation on the back).
Also how much would building regs come into it?!
Many thanks for your time and thoughts.
PostPosted: Thu Oct 13, 2016 11:47 am
Anyone?!
PostPosted: Thu Oct 13, 2016 12:18 pm
Has thanked: 656 times
Been thanked: 1858 times
Strictly speaking Building Regs are required when you make an area like this habitable. Of course you can do what you want to the space and it will only become an issue when you come to sell, especially if you advertise as a home office area.
In this instance there will be a requirement for insulation, fire escapes and the loft type access might not conform so you might be opening a can of worms to go down the official route. If you do it properly then it might be worth putting a dormer in to extend standing area and let more natural light in but this is heading into a costly project rather than giving some usable extra space. If you are not looking for added value to the property then you might want to so your own thing. :thumbright:
Painting with BIN
For this message the author dewaltdisney has received gratitude : Giblet46
PostPosted: Thu Oct 13, 2016 8:16 pm
Thanks, will probably do my own thing and maybe review down the line and see how much (££) needs to be done.
PostPosted: Sun Jan 15, 2017 9:42 pm
So I now have the house, and think I will be doing 'my own thing', and putting in an office. whilst I'm not sure I can fully build to regs, I want it reasonably close ( and warm!).
So looking a bit more closely, the rafters and joists are all 130mm depth, and understand i need 50mm ventilation on the roof tile side, so 70mm insulation between the rafters, and 'some' insulation under the plasterboard (thinking building to regs might cut the useable size of the room too much). However if I put in some knee boards and some sort of ceiling joist along the apex of the roof will maximise the insulation I can install.
Any thoughts on acces (currently the hole for the stairs is just....open) would the best option be a partition across with a door, or there other options I'm missing?
Sent from my SM-T800 using Tapatalk
PostPosted: Sun Jan 15, 2017 9:47 pm
Has thanked: 41 times
Been thanked: 1469 times
Heaven forbid it, but what if there was a fire in the garage and you are in the office how will you get out? (Better to figure it out now and never need to, than to...........)
PostPosted: Mon Jan 16, 2017 10:14 pm
I'll use the window to climb out, simple rope ladder should suffice! :)
PostPosted: Sat Sep 22, 2018 3:06 pm
So a bit of an update, project coming along, first up was the addition of an extra window, made it a lot lighter. I've installed some knee walls, 700mm high (wishing I'd made them 600mm for ease of fitting the plasterboard!) then used 75mm celotex along the rafters, the 'ceiling' and knee boards (not in the photo) and 50mm of fibre on the ends, all with a decent layer of vapour barrier over the top and then plasterboard.
Also extended the ring main for an extra couple of sockets, and some downlights (ceiling is only 205cm high).
Biggest learning curve has been the plasterboard, fitting properly (a few things I'd do differently next time) with a few gaps bigger than I'd really want (this is literally the first time I've done any sort of project like this), one of the most difficult parts of trying to fit the plasterboard sheets to the sloping ceiling!
Need to finish off, round the windows, then the joints which I'm really dreading!
Also thinking of a 'dog house' round the stair way, so walls round the side and back (for safety), then some sort of door/ lid for the top and front. (Mostly for insulation)... any ideas on this?! (Side hinge, end hinge with counter weight, sliding top!?)
For this message the author Giblet46 has received thanks - 2: big-all, dewaltdisney
PostPosted: Sat Sep 22, 2018 4:42 pm
Has thanked: 415 times
Been thanked: 1547 times
Just as well it's not under the Building Inspector: the rafters either side of the Velux windows should have been doubled up and also the trimmers, (and the BI would have wanted Jiffy hangers on the trimmer joints). I'd have put a top plate on the *knee* (Ashlar) wall.
For this message the author ayjay has received gratitude : Giblet46
PostPosted: Sat Sep 22, 2018 6:01 pm
Cheers for the points, I got a roofer to fit the second velux, seemed to think it would be ok with the load.
Some of the building regs do appear a tick box exercise :) the trimmers are only 40cm long and not structural.
Think the top plate on the Ashlar would have made the plasterboard fitting a bit easier though!
PostPosted: Sun Sep 23, 2018 7:53 am
Has thanked: 1 times
Been thanked: 46 times
Just a small point for someone that was in a house when it burnt down, if there is a fire in the garage, your intended escape route from the attic will take you down and across the lower window, they are the first to go and all the heat and flames will go upwards to singe your buttocks :cb as you come down, just make sure you have fire alarms and extinguishers, and learn how to use them.
If at all possible I would consider blocking off that garage window, this may seem a bit overkill, but bad things happen to the nicest of people. Nos
For this message the author Nos has received gratitude : Giblet46
PostPosted: Sun Sep 23, 2018 11:14 am
Thanks Nos, already got the smoke detectors (good idea for the extinguisher), it's a only first floor so the velux is the second route out (the new one does meet the fire regs in terms of height and size) . Did think about one of those emergency 'rope ladders' to help egress in worst case .
PostPosted: Thu Oct 25, 2018 4:05 pm
So update is that I've now finished! Pretty happy with it overall, considering I've never done most of the work before, plastering was good fun!
For this message the author Giblet46 has received gratitude : dewaltdisney
PostPosted: Thu Oct 25, 2018 4:23 pm
Well done, that looks good. Thanks for the update :thumbright:
Painting with BIN
PostPosted: Tue Nov 06, 2018 2:51 pm
Also finally sorted the other end out with the hatch. Neatest solution I could come up with unless I was to over complicate things!
