It is currently Thu May 24, 2012 9:45 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Sat Dec 03, 2011 6:29 am
Has thanked: 4 times
Hey,
Not sure if in the correct forum but here goes. Its a quick one :)
I am going to be installing some down lights in the bathroom.
the packet on the recessed lights advise on drilling a 66mm Diameter hole. I went to BnQ and found 64 mm and 70 mm Bits no in-between, which one should i use and buy as they cost quite a bit for only one bit??
Thanks,
JP
PostPosted: Sat Dec 03, 2011 7:59 am
Been thanked: 1 times
Free delivery if you spend £10
http://www.toolstation.com/shop/Power+T ... 530/p23014
And some for another day.
For this message the author Penguin has received gratitude : jp_101
PostPosted: Sat Dec 03, 2011 9:29 am
Troll Headbutter
Has thanked: 77 times
Been thanked: 130 times
I take your 64mm and raise you mm : http://www.toolstation.com/shop/Power+Tool+Accessories/Holesaws/Down+Light+Holesaw+Kit+9+Piece/d80/sd1530/p90948
BG :D
For this message the author BillyGoat has received gratitude : jp_101
PostPosted: Sun Dec 04, 2011 1:05 am
I guess ill be finding my receipt in that case.....
However which size would you recommend to drill with? I am drilling through a plastered ceiling with plasterboard behind.
JP
PostPosted: Sun Dec 04, 2011 8:40 am
Has thanked: 166 times
Been thanked: 612 times
get the kit Billy Goat links to and use the 65mm cutter, better to be 1mil snug than 4 mjl too large.
PostPosted: Mon Dec 05, 2011 12:19 am
Excellent many thanks :)
PostPosted: Mon Dec 05, 2011 1:06 am
Has thanked: 144 times
Been thanked: 217 times
I have to say if you have more than just a few holes to drill I would avoid that set like the plague! I bought that very set when I had forgotten my normal adjustable cutter one day. I wish I hadn't bothered!
If you have a number of downlighter to cut then get your self one of these, you can pick them up for around £30 (without the case)
If it's just a few then get a cheap pad saw for around £3
Professional Kitchen & Bathroom Fitters | Master Painters and Decorators | Brighton & Hove
