It is currently Fri Feb 23, 2018 4:25 pm
Visit Thermo worx
PostPosted: Thu Sep 14, 2017 3:43 pm
Hi after reading a few posts i couldn't find what i needed,
basically understand that i need to wire the hive up with 3 core + earth but struggling to find in what order,
(glowworm compact 80e)
on the guide for the boiler it has R2, R1 (that has a link that i believe i need to remove) one cable in the middle am not sure what its for and N L,
The N & L i believe is just a straight wire in but i cant figure out what the other 3 are for or were they go, there is a diagram on page 20 of the PDF i have linked to that i am working from.
any help is much appreciated (i haven't looked in side the boiler yet but wonted to know before i did)
Boiler
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Glow%20Worm/Compact80E_UIS.pdf
Hive
https://www.hivehome.com/img/attachments/Installation_Guide.pdf
thanks.
PostPosted: Sat Sep 30, 2017 2:38 pm
Hello ... Did you manage to figure out the solution. I am in same boat as you :(
Cheers,
Ankur
PostPosted: Sun Oct 01, 2017 9:36 am
Hi. Yes I sorted it this weekend. It wasn't too difficult at all.
First off I sorted the power so N&L and earth. That leaves the 2 at the top. It should have a cable that connects them both you need to remove this. So the first one it's numbered 1 goses to com on the hive And 2 gose to 3 on the hive. If you have the same boiler then I found that I had to turn the clock allways on. With no times set. So when the hive came on the bolier did to whole thing took about an hour. Hope this make sense if not I'll let me know. Good luck
