It is currently Sat Aug 18, 2018 9:41 pm
PostPosted: Thu Sep 14, 2017 10:03 am
Has thanked: 3 times
I have an Icon 23t that has had high pressure, i.e. over 3 bar on the gauge. The pump was leaking so that got changed as did the water topup connector, but the pressure still went up to over 3 but then came down again. What could be going on?
PostPosted: Thu Sep 14, 2017 2:24 pm
Has thanked: 827 times
Been thanked: 903 times
Is the filling loop properly turned off?
If so check the expansion vessel. Sounds like it is flat and needs repressurising.
At worst could be expansion vessel ruptured.
There is a 'how to' video on here about repressurising the expansion vessel
Dave
www.drlgas.co.uk
PostPosted: Thu Sep 14, 2017 4:00 pm
Thanks for your reply, I was wondering about the expansion vessel but it's supposedly had a new one recently. How will I know if it's flat or not, do I need to drain down to release the water pressure on it?
PostPosted: Thu Sep 14, 2017 4:01 pm
I'll check the video, sorry.
PostPosted: Thu Sep 14, 2017 5:41 pm
Yes you need to drain the boiler first. Press the shrader valve pin, if water comes out its had it.
Pressure should be around 1Bar.
Video should explain it all
Dave
www.drlgas.co.uk
For this message the author gas4you has received gratitude : davej
