-> Tiling Forum |
| Author |
Message |
Slugster Senior Member
Posted: Tue Sep 02, 2008 9:36 am Post subject: Hi or Low Modulus sealant |
Can somebody please tell me what the difference is?
I'm going to use the Dow Corning Sanitary stuff round the bath bog etc - this is just cos I'm a nosey bugger
Cheers _________________ Nothing you do is a waste of time - especially if it can be used as a bad example by others... |
| Back to top |
marc1106 Senior Member
Posted: Sun Sep 07, 2008 1:29 am Post subject: |
basically the LOW MODULUS is more flexible than the HIGH modulus, so if your sealing somthing that may move a fair bit( relativly speaking) use the LOW  _________________ IF IT WERE EASY ITD B BORING! |
| Back to top |
Posted: Mon Sep 08, 2008 9:37 pm Post subject: |
Thanks Marc ... _________________ Nothing you do is a waste of time - especially if it can be used as a bad example by others... |
| Back to top |
