-> Electric Forum UK |
| Author |
Message |
gaz Junior Member
Posted: Mon Jun 25, 2007 9:00 pm Post subject: Help with ufh |
Hi all just bought some underfloor heating by elektra. It say in the manual that a 30 mA resiual current protecting device must be installed, Can i connect it to my ring main which is protected by a 30 amp fuse, if so can i connect the t/e cable directly into the controller unit.
Also the ufh cable has two wire;s brown and white, i take it that the brown is the live.
gaz |
| Back to top |
Rich-Ando Approved Electrician
Joined: 24 Mar 2007 Posts: 2618 Location: Derby, Derbyshire
Posted: Tue Jun 26, 2007 12:17 am Post subject: |
| what is the actual rating of the UFH? |
| Back to top |
sparkydude Approved Electrician
Joined: 13 Aug 2005 Posts: 942 Location: Staffordshire
Posted: Tue Jun 26, 2007 5:22 am Post subject: |
You should be able to conect it via your ring main yes, but it depends where you are planning on installing it as to how you will connect it. you cannot just connect it to the twin and earth directly, you need to have some form of isolator fitted, and as you have said they recommend a 30 Ma RCD protection, this is nothing to do with the rating of the mains fuse, but the rating of the residual curent device RCD. If you have not got one on your fuseboard then i recommend you use an RCD spurunit to provide the suiable means of isolation and protection. As for wiring colour on your UFH i dont know without looking at the instructions, sureley it must say somewhere.
Nick _________________ If it isnt broke dont bloody touch it until it bloody well is and if it is broke then make drawing of the connections before you remove the broken one and replace with a new one LoL |
| Back to top |
gaz Junior Member
Posted: Tue Jun 26, 2007 5:29 pm Post subject: |
| Rich-Ando wrote: |
Its about 1000w |
| Back to top |
gaz Junior Member
Posted: Tue Jun 26, 2007 5:57 pm Post subject: |
| sparkydude wrote: |
Nick |
thanks nick i'll be installing it in my kitchen. |
| Back to top |
