It is currently Thu May 23, 2019 12:02 am
PostPosted: Mon Jan 07, 2019 7:35 pm
Has thanked: 7 times
Been thanked: 1 times
I would like to add some wall lights in my living room which will involve running some T&E cable from an existing light switch to an adjacent wall.
I am not sure which is the best way to route the cables, because if I go along the top of the wall (in the 150mm safe zone) then I will have to remove plaster board at each stud to drill a hole for the cable. The studs are 600mm apart so I estimate that there will be about 10 studs to drill through…. but that means I’ll have 10 holes in the plaster board to repair :(
So I made the first hole in the wall with a 114mm hole saw, the plan was to refit the cut piece of plaster board with a batten behind it for support...
The first stud I came across has me questioning whether its a load bearing stud (this is an internal wall). Can anyone confirm from the pictures before I attempt drilling holes in the studs ?
The picture below is the plan for the ground floor - note that this plan is for the opposite handed layout.
I bought an angled adaptor to drill into the studs, but unfortunately the drill bit is so long it won't fit in the hole !
I’m now wondering if running the cable under the floor boards in the room above might be an easier option ? The problem is the flooring consists of large pieces of chipboard. I have come across floor board hole saw kits which rebate the chipboard and provide blanking plates to cover the hole. But I would still need to make a hole every 600mm in order to drill holes through the ceiling joist, at least on the external wall side (the joists run in parallel with the internal wall so hopefully there will be no obstruction?).
The chipboard flooring above the living room can be seen in the picture below. This picture was taken before I moved into the property, the room now has carpet and furniture.
PostPosted: Mon Jan 07, 2019 7:45 pm
Has thanked: 41 times
Been thanked: 1480 times
Oh the joys of wanting new lights. Why are you taking the cable to the switch? have you looked behind it ?
For this message the author someone-else has received gratitude : skyrat
PostPosted: Mon Jan 07, 2019 7:57 pm
Yep, electrically its very simple.... its routing the cable itself thats the difficult and tedious task.
I have looked behind the switch, I intend to power and control the lights from this switch.
This is the existing wiring....
This is what I plan to do....
PostPosted: Mon Jan 07, 2019 9:28 pm
Ok, its just that most switches do not have a neutral. Wouldn't want to see you go to all that effort to find no neutral.
