It is currently Thu Feb 09, 2012 8:59 pm
PostPosted: Thu Sep 02, 2010 2:48 pm
Has thanked: 6 times
ok guys here is the problem, myself and the wif have just bought a 1930s house your typical semi dtached wit bay windows , now the guttering is leaking at about 3 of the joints not a great deal just basically dripping now budget isnt great and with the work in the house ect first i was hoping there maybe some sort of sealent i could posibly use that will last me through till next year
any help would be most appreciated
thanks in advance
john
ps the guttering is the old cast iron stuff i think anyway
PostPosted: Thu Sep 02, 2010 3:01 pm
OAP
Has thanked: 181 times
Been thanked: 1983 times
Easy.
Just cut the bolt off and buy new gutters bolts and nut, a small tub of Plumbers mait.
Ease the gutter up from the socket, clean and dry, apply a sausage of plumbers mait in the socket, and do the nut up.
Last for years.
PostPosted: Thu Sep 02, 2010 3:09 pm
will i be able to get these at the local b&Q or other diy stores
thanks
PostPosted: Thu Sep 02, 2010 3:19 pm
OAP
Plumbers or builders merchant would be best, although the sheds should have something on the shelf
For this message the author thescruff has received gratitude : tigerjonny
PostPosted: Thu Sep 02, 2010 3:22 pm
ok chers scruff wil give it a go
thanks again
john
PostPosted: Thu Sep 02, 2010 3:25 pm
OAP
If your not sure on a product other than the above, ask first, before you buy.
I'm out till about 10pm.
Silicon mastic is not a good substitute.
PostPosted: Thu Sep 02, 2010 10:46 pm
Been thanked: 7 times
same as scruff says but linseed putty also does the job ..
did a couple today :wink:
remember not to over tighten your bolt mate as the old cast gutters have a habit of cracking :wink
you usually hear a small creaking noise as it gets tight enough :wink:
remember to put a dab of putty or plumbers mate in the bolt hole to seal it up before you tighten it
allan
For this message the author agpm06 has received gratitude : tigerjonny
PostPosted: Thu Sep 02, 2010 11:20 pm
OAP
Don't like putty as it dries out and goes hard, ok if nothing better is to hand.
Users browsing this forum: clarke and 7 guests
