It is currently Mon Dec 17, 2018 5:19 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Tue Oct 17, 2017 1:48 pm
Has thanked: 26 times
Been thanked: 1 times
Hi all, I've received a new timer based photocell and wondered if someone could help me with the wiring?
The current dusk till dawn has black, brown, grey and earth wires and this is what I will be attaching. Can someone please explain how I should wire this?
Loves to ask questions.
PostPosted: Tue Oct 17, 2017 7:04 pm
Has thanked: 45 times
Been thanked: 1382 times
It depends on how who ever wired the current sensor chose to wire it.
Can you look at the current sensor and see what wire does what.
Pictures would also help.
PostPosted: Tue Oct 17, 2017 7:59 pm
Has thanked: 1507 times
Been thanked: 3811 times
Your new switch./pir has a permanent live/neutral in and is switched by the PIR; I can only imagine that the old unit was an integrated unit that needed a permanent live/neutral and switched live.
unless you are comfortable using a multimeter on 230V live then I would suggest getting an Electrician in.
PostPosted: Tue Oct 17, 2017 8:17 pm
Thanks very much, I do have a meter thats been very rarely used so if you have the patience to explain what I need to do I will gladly follow. I will also provide photos of what I can see tomorrow morning when light.
There is no switch controlling the light.
Many thanks,
Devs.
PostPosted: Tue Oct 17, 2017 9:01 pm
The "thing" with a multi meter and mains is, get it wrong and ............... (That is looking at the worst case scenario)
I would suggest you learn how to use it first, learn how to check for continuity, and voltage of batteries etc (see the university of Youtube)
In regard to your existing sensor, yes, take and post a many clear pictures as you can.
PostPosted: Tue Oct 17, 2017 9:30 pm
Okay fair comment, I'll take another look in the morning and provide as much info as I can. Many thanks.
PostPosted: Tue Oct 17, 2017 10:38 pm
:thumbleft:
PostPosted: Wed Oct 18, 2017 9:56 am
Okay I've just had another look at this and below you will see how the existing wires were connected and how I have connected them into the new unit.
As far as I can tell this is correct and have masked off the sensor to try and trigger the light but it didn't work :(
Any suggestions chaps?
Thanks.
PostPosted: Wed Oct 18, 2017 5:07 pm
New unit has input live and neutral to the outer two connections as per the instructions. a separate cable (L/N) from the middle pair to the light.
Just guessing (as you have done) will end in tears...
Can you tell where the cable to the old light comes from ?
PostPosted: Wed Oct 18, 2017 6:35 pm
Wine~O, is it me or do you only see 1 cable at: The "sensor", and another at the "off white" box?
Where is the supply coming from? there is some thing missing.
PostPosted: Wed Oct 18, 2017 6:57 pm
I'm reading it as the new white box (pic 3 above) has a load and supply to the lamp.
The old lamp is not compatible as it has an inbuilt sensor.??.. I know what I mean difficult to explain via a few photo's and a forum.
PostPosted: Wed Oct 18, 2017 8:40 pm
Evening. I just wanted to update. The new unit is wired up and live per the image that I posted previously.
The light has illuminated and has been for sometime. I was hoping that it would turn off as I was sure that I set it to 1hr for testing..
I think my next job is to open the light up and see how its wired..
PostPosted: Wed Oct 18, 2017 9:03 pm
Please STOP. DO NOT PASS GO. (monopoly jest) you may well have already damaged the new sensor.
GET AN ELECTRICIAN IN.
There is only so much that can be done via a forum.
For this message the author wine~o has received gratitude : devs
PostPosted: Wed Oct 18, 2017 11:11 pm
I was also wondering (in respect of the pictures)
is this
One of
and are you replacing it with
PostPosted: Thu Oct 19, 2017 7:37 am
Hi, yes that's correct..
