Ultimate Handyman Home
Help! There's a hole in my floor :(
Post new topic   Reply to topic   Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum
darkbagpuss
Junior Member
PostPosted: Mon Oct 06, 2008 11:16 am    Post subject: Help! There's a hole in my floor :( Add User to Ignore List Reply with quote
Hello,
We've recently moved into a 1970's house and I was planning to set about replacing the existing grotty carpet with a nice engineered wood floor this weekend. Unfortunately, I've just lifted up a wooden 'sill' that sits in front of the patio doors and have been horrified to find a large whole (approx. 1m x 15cm, up to 10cm deep) in the concrete floor underneath, with the sill supported by some offcuts resting on some rubble. It's obviously been done by whoever installed the door but looks a mess. For about 10cm in front of the door it's only about an inch deep but then quickly drops off under the patio door itself and I can see the exterior brickwork. Could anyone tell me the best way to fill this hole? Please?
Thanks!
Back to top
leebwk
PostPosted: Mon Oct 06, 2008 2:45 pm    Post subject: Add User to Ignore List Reply with quote
any chance of some photos?
What was the best thing before sliced bread?
Back to top
darkbagpuss
Junior Member
PostPosted: Tue Oct 07, 2008 9:52 am    Post subject: Add User to Ignore List Reply with quote
Will try and get some piccies tonight but any general advice in the meantime? I suspect I may not have time to fill the hole and have it dry before the weekend...
Back to top
darkbagpuss
Junior Member
PostPosted: Wed Oct 08, 2008 8:23 am    Post subject: ...now with pictures! Add User to Ignore List Reply with quote
I've taken some pictures of the offending area. Hopefully this shows more clearly what the problem is. The depth of the first 'step' down in the concrete is approx. 2cm. The wooden blocks are resting on some heavy felt-like material. It then falls off just before the patio door to a depth between 5cm and 7cm. There appears to be some rubble in there. As I'm planning to put down engineered wood floor, I'll obviously need this area flat and stable. I want to get it right now as I don't want to be pulling up wood flooring later to correct any problems later. I haven't done any work with concrete before but something tells me it's not quite as straightforward as mixing some up and bunging as much in as I can. Any advice very much appreciated.
 Description:
A bit blurred but it's a better view of the gap under the door.
 Filesize:  26.6 KB
 Viewed:  240 Time(s)
 Description:
Spot the wildlife! You can also see the drop off under the door itself.
 Filesize:  38.37 KB
 Viewed:  240 Time(s)
 Description:
Depth of the small step the wood blocks are resting on is 2cm
 Filesize:  38.26 KB
 Viewed:  240 Time(s)
 Description:
View from above, the width from carpet to patio door is about 15cm
 Filesize:  34.38 KB
 Viewed:  240 Time(s)
 Description:
This is the offending area
 Filesize:  31.3 KB
 Viewed:  240 Time(s)
Back to top
Tryanything
PostPosted: Fri Oct 10, 2008 1:27 pm    Post subject: Add User to Ignore List Reply with quote
Hi
Can you have a look and determine the height of the damp course in
relation to the bottom of the cill
If you can't see it outside, lift up the bit of damp course (the thick felt material) that is covering the cavity inside
Reason being we need to find out if the damp course was breached when the patio doors were fitted
Also what direction do you intend to run the flooring
Tony Tiger
Back to top
Display posts from previous:
Post new topic   Reply to topic    Thank Post    www.ultimatehandyman.co.uk Forum Index -> Building Forum All times are GMT
Page 1 of 1
