It is currently Thu May 24, 2012 9:04 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page 1, 2  Next
 Post subject: Help
PostPosted: Wed Jan 04, 2012 10:20 pm
Has thanked: 10 times
Been thanked: 4 times
Hi there, reached round to get some bog roll from the sink unit and it was wet, on closer inspection all the plastic couplings were loose, tightened them up but the water kept coming!, it appears that the water is coming from the joint at the sink, it was also loose! tightend that but it is still leaking any advice about how to fix this would be appreciated.
It was fitted 3 years ago so couldn't have been leaking since them.......................help
Thanks in advance
 Post subject: Re: Help
PostPosted: Wed Jan 04, 2012 10:38 pm
OAP
Has thanked: 187 times
Been thanked: 2113 times
Have you turned the water off.
How do you mean loose, are they push fit fittings, or compression.
PostPosted: Wed Jan 04, 2012 11:16 pm
Hi Scruff, they are all screw fittings, but where the waste pipe/fitting meets the sink there isn't a visable nut to tighten the sink had an intrgral plug operated by a plunge up/down mechanisim at the back of the taps, the plug isn't attached to the mechanisim but looks like it should be, anyway the leak is definatly coming from whrere the waste meets the pipe, it's an Ideal standard sink and at the leak point there is no nut to tighten.
Thanks in advance
PostPosted: Wed Jan 04, 2012 11:17 pm
OAP
Can you post a pic please :scratch:
PostPosted: Thu Jan 05, 2012 12:18 am
Hi there, I've yaken a few shots but don't know if I will post them acuratly!!!!!
PostPosted: Thu Jan 05, 2012 12:20 am
OAP
Should be easy enough, if not I'll pm you an email addy and you can send them to me.
For this message the author thescruff has received gratitude : caravan72
PostPosted: Thu Jan 05, 2012 1:42 am
caravan72 wrote:
PostPosted: Thu Jan 05, 2012 9:04 am
Sorry, to much beer last night and a foggy start to the day and I can't still post a picture!
will try again
PostPosted: Thu Jan 05, 2012 9:16 am
Has thanked: 166 times
Been thanked: 169 times
click full editor, browse -> add file -> place inline
- Dave
http://www.pamperhouse.net
http://www.invertedcircle.co.uk
PostPosted: Thu Jan 05, 2012 9:44 am
OAP
will try again
Or read your PM's and send them to me in an email. :mrgreen:
PostPosted: Thu Jan 05, 2012 10:41 am
OAP
That looks like it's running down from above, is water getting in around the tap.
Also check the overflow.
PostPosted: Fri Jan 06, 2012 12:25 am
Hi again, I had a closer look and it seems the water is coming from the waste connection where it meets the sink can't feel water above that level, the leak is worse after the sink is used so looks like its the connection. How or what should I use now to fix it?
Thanks in advance
PostPosted: Fri Jan 06, 2012 12:32 am
OAP
I was looking at the drips above the waste on the chrome.
The trap is easy to solve and someone has made the classic mistake.
Remove the trap, (don't empty it in the sink) and cut 3mm off the nut where it screws unto the waste, and replace, problem solved.
PostPosted: Fri Jan 06, 2012 12:18 pm
Hi Scruff, the water is coming from where the chrome meets the sink and not the plastic nut, could this be easily disconected and sealed with something?
Thanks in advance
