tsmiggy Junior Member
Posted: Tue Sep 30, 2008 10:58 am Post subject: Help....... |
I have a Potterton boiler running my central and hot water system.My system uses a honeywell 3 way valve in the airing cupboard.The problem that as now appeared is that once the hot water is up to temperature the central heating will not work.If i then switch off the hot water at the programmer in the kitchen the central heating works fine.Once i switch the hot water back on,then the central heating stops.Everything will work fine,until the hot water is up a its full temperature.My gut instint says the Honeywell 3 way valve,but i have also thought about the thermosat on the cylinder.Any help or pointers would be very much appreicated.
cheers |
